Drop Spindles and worn brake hoses
So, after a lot of time under my truck redoing the front brakes... I noticed that due to the drop spindle (I am guessing), the factory hoses rub along the upper ball joint nut. Mine sits right on it... I got new hoses (haven't installed them yet) but, what does everyone do to keep the hose from getting worn from the ball joint nut? I don't want to bend the aluminum portion of the hose too much because it will crack... any ideas or fixes you have seen in the past?
I have to go back under the truck tomorrow so, I will take pics if it helps.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
Re: Drop Spindles and worn brake hoses
The end of the hose is most likely steel, and not aluminum, and you should be able to bend it far enough to clear the ball joint without doing any damage to the hose. I believe that is what most people do, I have personally bent the front brake hoses a number of times with no problems.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Bend it.
That’s the way I’ve been doing it for years.
Hoses bent and on.... the passenger side was a PITA! Had to take out the alternator to get to the back then, the PO had a washer on the outside vice the horseshoe clip.
Back on the road blasting my 80s miami bass and pissin off the neighbors with my 40 flowmasters. Life is good!
I had the same deal... Read up on here to bend it. No problems so far.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
