Radiator Support
WELL JUST FIGURED OUT I HAD 69 RAD SUPPORT ALL DONE AND PAINTED TALK ABOUT BEING BUMMED OUT BUT.... IT DOES WORK WITH SOME MODS. PULLED OUT OLD SUPPORT SEEMS ALL STAMPINGS ARE THERE UNDENEATH ONLY DIFFRENCE IS HEADLIGHT MOUNT AREA HAS STANDOFF OVER ORIGINAL STAMPING. AND HOLES FOR MARKER LIGHT HIGHER THAN ORIGINAL MADE TEMPLATE OFF OLD SUPPORT AND MADE ADJUSTMENT HOLES AND SPRING POSITION STAMPED UNDERNEATH NOT THE BEST WAY TO GO ABOUT IT BUT TOO FAR ALONG TO CHANGE NOW PLUS THIS ONE OEM OH ALSO 69 HEADLIGHTS HIGHER AND INBOARD HAD TO OPEN HOLE UP ABOUT 1/2 IN OUT AND 1/4 IN DOWN.. JUST THOUGHT I WOULD LET YOU GUYS KNOW JUST IN CASE YOU RAN INTO IT TOOK A TOTAL OF 2 TO 3 HOUR TO COMPLETE DRILL OUT SPOT WELDS DRILL HOLES FILE SQUARE REAM HEAD LIGHT HOLE
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Ouch I had the same problem when I was gathering 68 front clip part's I paid an arm and a leg for a 68 core and it turned out to be a 72... I guess I learned the hard way..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
