Old 04-16-2019, 06:49 AM   #1
chrismoore701
chrismoore701's Avatar
Pinion seal
So i changed the seal on my rear end last year and it still sprays diff fluid all over the underside of the bed. I am thinking to replace the yoke. If that’s the right term. Will this work? How do i know which one to get? How do i hold the fluid from pouting out during the match up? I will also replace the seal again.
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-16-2019, 09:37 AM   #2
geezer#99
geezer#99's Avatar
Re: Pinion seal
Is the vent clear?
Old 04-16-2019, 01:40 PM   #3
chrismoore701
Re: Pinion seal
yes
Chris
Old 04-16-2019, 06:50 PM   #4
sweetk30
sweetk30's Avatar
Re: Pinion seal
i also add some rtv on the splines and the washer before it gets put on the pinion before the nut . gear oil can sometimes creep up the splines and around the washer and sling around .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-16-2019, 08:11 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Pinion seal
What about the crush sleeve and rotational torque when swapping the yoke?..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-16-2019, 08:32 PM   #6
chrismoore701
Re: Pinion seal
Don’t want to swap the yoke. Just looking for opinion on the seal and mating surface. Changed the seal once already and still leaking
Chris
Old 04-16-2019, 08:50 PM   #7
mongocanfly
Post Whore
Re: Pinion seal
Either way your pulling the yoke
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-17-2019, 07:20 AM   #8
chrismoore701
Re: Pinion seal
Sorry, had my parts mixed up. The yoke is what I am looking to replace. You dont have to pull the crush sleeve when pulling the yoke. Had it off to replace the seal lat year. That is the question at hand. I replaced the seal and still leaks. will replacing the yoke solve my problem? Could that be worn where the seal sits? or what else could be my problem. Frame off restoration, so the bottom is clean and there is lube sprayed on the bottom of the bed at the front seal.
Chris
Old 04-17-2019, 07:56 AM   #9
mongocanfly
Post Whore
Re: Pinion seal
Did the yoke have a wear groove in it when you changed the seal?is there any play in the pinion?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-17-2019, 10:54 AM   #10
chrismoore701
Re: Pinion seal
That I don't know
Chris
Old 04-18-2019, 03:53 AM   #11
Jaysonb
Jaysonb's Avatar
Re: Pinion seal
I would try a speedi-sleeve on the yoke you have, and a new seal.
Jaysonb is offline   Reply With Quote
Old 04-18-2019, 11:01 AM   #12
1957 Chief
Re: Pinion seal
Agreed.
Bubba
1957 Chief is offline   Reply With Quote
