Driveshaft...
Where is the best place to get a new driveshaft for a long bed truck ???
It's been a long time coming... It's time to get it done.. ![]() |
Re: Driveshaft...
Do you have the old one? Is it a standard duty or Heavy Duty shaft (can tell by the carrier bearing- Light duty bearing has one mounting point, HD has two points)
If you have the HD shaft, you should just rebuild it as long as you don't need a longer one. For the money invested it's the strongest driveshaft you'll find. |
![]() Join Date: Sep 2005
Re: Driveshaft...
Any good driveshaft shop can build one or rebuild yours with new bearings and a good balance i kept breaking the carrier bearings on mine last time ti did i took it and had a drive shaft shop go though it was around 100 buxs for new joints carrier brearing and balancing the shaft its been 15k miles not had an issuse since
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
![]() Join Date: Jun 2017
Re: Driveshaft...
I have a bran new aftermarket carrier bearing just sitting in my garage if you need one. I can sell it for 75%.
Re: Driveshaft...
I have the two bolt carrier but I also need it to be longer... I can't find any driveshaft shops my area that specialize in making them … I was thinking of ordering one online just have never done that....
