Swapping radiator problems 1984 Silverado
Got a question for the group. I'm in the middle of swapping on parts from a 83 gmc c2500 I stripped a few years ago and putting them on my Chevy k2500 and just noticed now the radiator I'm putting in the Chevy from GMC had a different heat hose routing system. My Chevy has the hoses from water pump to heater core to intake and the radiator I'm putting in is ment to have heater hose from radiator to heater core to intake. My question is what should I do with the hole for the heater core now since my engine wont require me to use it and if I have to plug it what's the best method, it is not a threaded hole just a hose clamp one.
On a quite night you can hear a ford rust |
Re: Swapping radiator problems 1984 Silverado
Hose from intake is the hot output. Hose to either radiator or water pump is return. Most water pumps have a threaded place for either a hose port or plug. If your radiator is fitted for a return hose, just get a plug for the water pump hole.
Don't make the mistake of running from water pump to core and back to radiator. |
I didnt even think of plugging the water pump. Thank you!
Unless you have Vortec heads on a non-vortec block, but that's a whole nuther can of worms.
What do you mean by that?
It's an issue and workaround for the coolant bypass hole. If you have this setup, it's worth looking into. If not, I wouldn't give it a second thought.
I do want to keep my heat so is it possible to just take the heater core hose off my water pump and attached it to my radiator then get a plug for the water pump. Or are you saying doing that could cause problems with the weep hole on the water pump? Would it be worth it to just replace the water pump with one that does not have the heater core hose hook up.
#9 | |
Normal heater hose flow is from intake to bottom of heat core, top of heat core back to either water pump or rad. Yours has the bung on the rad so put the hose there and plug on the water pump. |
Awesome thank you
![]() Join Date: Jul 2000
The mention of Vortec heads above reminds me of a problem I have with my cooling system: I can sometimes hear "gurgling" in the heater core, and one of the heater hoses sometimes thumps against the inner fender.
I have GM Vortec heads and a 1997 350 Vortec block. After filling the cooling system I can "burp" the system a few times until no more air bubbles flow into the reservoir. But still the gurgling persists. I have the tools to evacuate the cooling system and suck in fresh coolant, but the vacuum causes my radiator hoses to collapse, which prevents me from evacuating the system entirely. Any ideas?
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Put a coil in your hoses.
#13 |
Good idea, but I couldn't find just a coil, or a hose with a coil to fit.
#14 |
Make a coil.
I’ve used 10 feet of galvanized wire and wrapped it around a solid 2 inch pipe. Stretch it out like an accordion and then put a pigtail on each end so it can be wound into the hose easily. |
#15 |
Sounds like a plan!
Just found this lower hose. Looks like it may have a coil inside. https://www.rockauto.com/en/moreinfo...030824&jsn=449
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-18-2019 at 03:17 PM. |
