aftermarket hood hinge
Has anyone used the aftermarket hinge, if so which one? My hinges are so bad that I can't believe they dont come apart when I open them.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
![]() Join Date: Mar 2019
Re: aftermarket hood hinge
I've used aftermarket from LMC Truck.
Part numbers 30-3824 LH and 30-3825 RH. They are without spring and there $44.95 each. they work fine on my hood. Not as beefy as the originals but they do the job. |
![]() Join Date: Mar 2005
I also bought aftermarket hood hinges and springs for my 70. Works way better than the worn out original ones.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
![]() Join Date: Dec 2013
Manes Truck Parts sells good used hinges if you prefer oem.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
