Which manifold?
What kind of manifold would be a good one for a 350 with a quadra jet 600 cfm? Not looking for a hot rod here just a decent one.
Thanks a bunch |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I went with the performer by edelbrock seem's to work very nice...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Was it the standard eps? How much did it cost anyway?
Thanks |
PROJECT 7DEUCE
I got a non egr from summit for 129.95 satin finished...
Not to bad. What about the oil tube?
Thanks |
PROJECT 7DEUCE
My motor did not have the oil tube so I did not put one back on..
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Where did you get a 600 cfm quadrajet? The only two varieties that I am aware of are 750 and 850 cfm.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
My other Love
if you have an oil tube, upgrade your valve covers so one has a hole for a breather/ oil filler
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Yep you are right. I meant to say 4 barrel but quadrajet came out. Heres my carb minus the shiny.
http://www.holley.com/HiOctn/ProdLin.../0-80457S.html |
its all about the +6 inches
If your engein is pretty much stock, then just go with any intake advertised for idle to 5500 RPM. I noticed considerable gains on a stock well worn 300,000 mile old 350 when i installed the performer, but I hear it is an outdated design. maybe a Wienand is in order?
most of the intakes in that class are right at about 100 bucks mail order. |
Ok is there anything in the oil filler that I will need for the valve cover? Besides a oil cap?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Thanks Longhorn Man. BTW beside disconnecting the top radiator hose,carb, and distributor what else needs to come off? Or could I leave the carb on?
thanks |
#13 |
Don't say "Oops!", Doctor
What's Weiand got that beats the Edelbrock Performer for a relatively mild engine? Those freakin' Performers are really, really popular. Heck, I've used a couple of Performer RPM on mild 350 engines with pretty decent results. Unfortunately, it looks like I'll be digging into the top end of my 68's engine and it'd be as good time as any to upgrade from the stock iron.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
#14 |
My other Love
well if you get a valve cover with an oil cap you also have to make sure you have a way to make the crankcase breathe or else you are looking to blow out seals and what not, just make sure you get an oil cap that also functions as a breather or have a valve cover with an oil cap, and the other valve cover with a breather
#15 | |
Like I said...I have used the performer and had noticiable increase in power...however, i have been told it is an out dated design. Ford sold Escorts by the millions in the 80's...best selling car in teh WORLD for like 8 years...that doesn't make it a GOOD car, we all know it was a POOR DESIGN....it sold becouse it was CHEAP. Again...I support the performer. The Performer RPM is a whole nother ball game. And it IS a kick ass intake, but I would not recomend it for a stock or near stock engine. |
#16 |
I saw this one at summit racing:
EDL-2701 Chevrolet: 262-400, 1986 and earlier cylinder heads, dual plane, cast aluminum, Performer EPS, intake manifold. Is this the one you are referring to longhorn man? |
#17 | |
#18 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Weiand got nothing on Edelbrock. I bought one of their Stealth manifolds for SBC a few years ago because Summit had them for 94 bucks. Fit like ass. It was too high near the valve covers and wouldn't let my aluminum covers bolt down without hitting. I sold it and put an Edelbrock on it.
I have tons of Edelbrock stuff hanging all over my garage wall. Never had one single complaint about Edelbrock stuff. Get a Performer pn 2101 and be happy.
#19 |
I should clarify, I have tons of Edelbrock stuff on the wall because I collect old Edelbrock goodies off of forum boards and Ebay.
#20 |
Will the 2101 work with my carb?
Heres a link for my carb. minus the shiny. ![]() http://www.holley.com/HiOctn/ProdLin.../0-80457S.html The only major difference I can see in the manifold is that on the 2101 there is a divider in the hold. On my there is no divider. thanks HAPPY TURKEY DAY!! |
#21 |
Yes it will. I have one in my garage right now, with the same carb on it. Works great!
#22 |
Hmm that brings up another question for you now. Regarding my motor will that manifold work on it
33417369...90-up...350..........Gen.I Goodwrench crate motor, "Hecho en Mexico", 76cc |
#23 |
If it has the normal valve covers with 4 bolts around the edge, it will fit.
It it has the 4 valve cover bolts in the center of the covers, it won't. It sounds like you probably have a generic old Goodwrench engine, which uses the normal intake.
#24 |
Heres a pic of the valve covers. Looks like it wont fit from what you have said in the other post. According to this the motor is a 90 and up
33417369...90-up...350..........Gen.I Goodwrench crate motor, "Hecho en Mexico", 76cc Any idea what manifold would fit on that one? Thanks Last edited by skokie; 11-27-2003 at 09:37 PM. |
#25 |
You're good to go on the part number 2101. Those are the normal old style heads you have there.
The new style heads have the 4 valve cover bolts on top of the valve cover where yours say "Chevrolet"
