Old 04-18-2019, 09:54 PM   #1
rockyrivermark
Vacuum question
Small block
I have a vacuum reading of 20 on the manifold
I have a vacuum reading of 10 on the carb ports.
Checked two ports to verify.
Should the carb and intake vacuum be the same?
If so I'm guessing carb gasket?
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 04-18-2019, 10:13 PM   #2
Wrenchbender Ret
Re: Vacuum question
No they are not always the same. Most outlets on the carb are ported vacuum. They are on the upper side of the throttle valves. They are used often for emission control items. Sometimes the ported vacuum is used for dist advance. That varies with different engines. At part throttle about 2-3 k RPM's they will be near the same.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-18-2019, 10:16 PM   #3
Wrenchbender Ret
Re: Vacuum question
They will not be the same. Most outlets on the carb are ported vacuum. They are used mostly for emission control devices. Some engines use ported vacuum for dist. advance. They will be near the same at no load part throttle.
George
Old 04-18-2019, 10:35 PM   #4
rockyrivermark
Re: Vacuum question
Oh. Got it. Thanks!
My build page
Old 04-19-2019, 10:38 AM   #5
68 P.O.S.
Re: Vacuum question
Correct, manifold and carb may not always match. One factor is the condition of your carb. With the vac gauge still connected to the manifold vac inlet on the carb, adjust the idle mixture screws for best vacuum. Hopefully your vac will get a little higher than 10" at the carb.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-19-2019, 10:50 AM   #6
davepl
davepl's Avatar
Re: Vacuum question
Any ports BELOW the throttle blades should match the manifold, though. Any ports above, will depend on how they're routed internally (like ported vacuum for the dirt).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
