04-19-2019, 07:18 AM | #1 |
Power window harness
I’m changing my manual doors over to power windows and power locks. Does anyone know where I could purchase the wiring harness to do this. Thanks in advance for your help. Darin
Posted via Mobile Device |
04-19-2019, 09:16 AM | #2 |
Re: Power window harness
there someone on here that makes them,I sure he will post soon.Any pics of the install mostly the boot area where the wires go thru, I,m about to do this soon
04-19-2019, 03:01 PM | #3 |
gmachinz makes them. He's on here all the time.
04-19-2019, 08:55 PM | #4 |
Check eBay. Found a complete kit on there
04-19-2019, 09:58 PM | #5 |
If you can find the setup in a junkyard or ebay that would be a good option, but these old systems get to be quite slow in operation. You can also get a relay upgrade kit from LMC which will help quite a bit. Or, there are a few vendors online who sell the entire set up which will be all new components but it usually does not look factory. A factory look will require the use of factory style switches.
04-20-2019, 04:19 PM | #6 |
Moderator
Cleaning and lubricating the motor will help a bunch. Lubricating the linkage is a big help too.
After 40 years you'll also want to replace the guides and scrapers with good quality pieces. Be sure to lube the fluffy flocking in the new guides with powdered graphite or a dry silicone spray. Don't use anything that stays wet or greasy. I lean toward the graphite powder as it won't eat the rubber that makes up the base of the guides. IIRC There's a writeup somewhere on this board for replacing the side window guides and scrapers. Not difficult but it's fairly fussy to do it right.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
04-20-2019, 04:23 PM | #7 |
I had a pair of good 77 power regulators. I was thinking I would put new later model motors on them. I have found the harnesses at Eckerts. Does all this sound Savy??
Posted via Mobile Device Last edited by katykitchen; 04-20-2019 at 04:36 PM. |
