Old 04-19-2019, 02:47 PM   #1
Sim6
Sim6's Avatar
Bagged 88-98
Question, do you have to replace the front control arms to bag and lay frame on these trucks? not going to body drop. thanks
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 04-19-2019, 04:24 PM   #2
shifty
Questionable
shifty's Avatar
Re: Bagged 88-98
We need to have a suspension FAQ for 88-98 trucks.
Like ... showing a few visual samples of drops: 0/2, 2/3, 2/4, 3/4, 4/6, 5/7, 6/8, bagged, bagged & bodied. Needs to include what kit and/or option was used (spindles, springs, shackles) and whether UCA/LCA or other components were replaced, shock mounts relocated, sway bars added etc.
Would be cool to see with aftermarket and stock wheels.
Also needs to include considerations when doing it... like whether you'll:
- Need to notch bed support in rear if you go beyond 2-3" in these trucks, for example, because the leaf spring support will hit or something
- Need to notch LCA once you get below XYZ inches in front and/or when using smaller (factory) wheels.
- Need to notch rear frame rales once you get below XYZ inches in rear
- etc. etc.
And any other considerations one would need to worry about. I found that type of thread extremely helpful when I was bagging my '68.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-22-2019, 01:13 PM   #3
Stormin08
Stormin08's Avatar
Re: Bagged 88-98
this is stock frame, with a c-notch and the bed support trimmed above the pumpkin
i want to say i run a 27" tire.
i can slide my hand under the mid frame rail and drive forward as it sits.
FRONT: 2" drop spindle, Ridetech shockwaves
REAR: KP Components 6 Link
AIR Management: Accu-Air E-Level
Stormin08 is offline   Reply With Quote
Old 05-01-2019, 01:40 AM   #4
54Caddy
GM Addicted
54Caddy's Avatar
Re: Bagged 88-98
Bolt in style c notch. Or larger welded in under bed notch?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 05-02-2019, 01:20 PM   #5
Stormin08
Stormin08's Avatar
Re: Bagged 88-98
bolt in that has been welded, i should redo it with a taller weld in.
