Noise when shifting into drive
Sometimes when I shift my truck into drive and then let off the brake and give it a little gas to move forward I hear a loud clunking noise, almost like a ding. It seems to be coming from the rear end. Once it makes the noise it will not do it again until I stop and put it in park and then drive and take off again. It is an intermittent issue. I have the original Dana 60 in the truck. Has anyone else come across this issue?
Post Whore
![]() Join Date: Feb 2016
Re: Noise when shifting into drive
I would first check the ujoints for slop. Park on a level surface, block front wheels, put in neutral. Grab both yokes of to a ujoint and twist them. You should have zero play.
If this all checks out then twist the pinion yoke on the rear axle. It should have some play but not be excessive. You may have to look at some videos or get qualified second opinion if it is more than about 3/16 of play.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
HO455 gives good advice. If you get through those checks without any bad signs, look at the transmission mount and engine mounts. U-joints are good for making a "ding", while mounts and rear diff are more of a "clunk".
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#4 | |
Motor mounts are fine as is the transmission mount. |
Post Whore
It is possible that the ring and pinion are worn. But there are other components inside the rear end that likely have worn over time and each one is contributing to the play you are seeing. If you are not hearing any excessive whining or howling from the rear end I would not suspect the ring and pinion to be worn out. A trip to a competent rear end shop would find the answer.
I know when I had my rear end rebuilt I was amazed at how much quieter and smoother my truck was afterwards. Although truth be told mine was in the process of disintegrating when I took it in.
Moderator
![]() Join Date: Jun 2017
Remove the driveshaft and add high small amount of temp grease to inside of yoke...
Replace driveshaft... This "ding" is a common Chevy problem...the splines wear and develop small amount of excess clearance...the hollow driveshaft accentuates the sound... There is a Service Bulletin that's been around for decades on this issue... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#7 | |
#8 | |
I'll take it over to a differential shop. If you don't mind me asking how much did it run you to rebuild your rear diff? |
[quote=SavageC20;8510466]I grease the slip yoke regularly and the noise is still there.[/quote
#10 | |
Post Whore
If I remember correctly the original quote was about $400 for all bearings and seals to be replaced
I had a noise that sounded very similar to your description - it was simply the u-joint at the rear diff. Easy fix to do yourself. I replaced the front u-joint while I was at it.
Mine didn't have any noticeable slop while twisting, and I actually missed finding the bad joint for a while because of this. I found mine was bad when I put it up on jackstands and put it in drive, accelerated, then let it coast while I watched it spin down... there was a definite noise from the rear u-joint. Shut the truck down and found that by applying lateral pressure on each of the u-joint's axes (each axis), I could get a little play from one of them that wasn't detectable if only twisting the joint. Replaced it and all's good.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#12 | |
I'll try the same thing with mine to see if I can find any play in it. The u-joints I have in it only have 1000 miles on them but who knows could be defective or something. |
#13 | |
![]() Join Date: Oct 2009
