Old 04-19-2019, 06:08 PM   #1
jdl71
jdl71's Avatar
Eaton ho72
I picked this up today. Has 4:10 gears and I think a no spin. I can’t see a center pin, all 4 holes on the carrier have something in them if that makes sense. How can I tell for sure?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-20-2019, 12:30 AM   #2
raylube
raylube's Avatar
Re: Eaton ho72
Looks like a open diff
.No spins don't have the spider gear that is shown in your photo. Should have numbers on ring gear to tell gear ratio and date code. They don't use center pin but a cross set up on both open and no spin
raylube is offline   Reply With Quote
Old 04-20-2019, 08:50 AM   #3
jdl71
jdl71's Avatar
Re: Eaton ho72
Thanks. It is 4:10 made in 1970. I tried to get that in photo but it doesn’t show up very well.
Psalm 23
64 C10
66 K20
Old 04-20-2019, 08:51 AM   #4
jdl71
jdl71's Avatar
Re: Eaton ho72
Next question. Will this center section bolt in to my 52 housing?
Psalm 23
64 C10
66 K20
Old 04-20-2019, 09:35 AM   #5
raylube
raylube's Avatar
Re: Eaton ho72
Yes the center section it should bolt right in. However the gear ratio does not match the front so you will have issues there. So either regear the front or replace the carrier with the new axle to fix yours keeping your 4.57. Or never shift out of 2wd.
Old 04-20-2019, 09:58 AM   #6
Getter-Done
Getter-Done's Avatar
Re: Eaton ho72
I can't answer your question but I have 2 links saved
that are an interesting read.
1st one has info about spider gears.
2nd one has good pictures to show what the Eaton looks like torn apart.
Link 1: http://67-72chevytrucks.com/vboard/s...ding+HO52+HO72
Link 2: http://67-72chevytrucks.com/vboard/s...d.php?t=536119
Hope this helps and in no way am I try to make this about a 14 bolt swap subject.
I want to run my Eaton also.
I have 3 center chunks.
One of them is an early Eaton that have one pinion bearing an a bushing in the rear of the pinion.
The other 2 have pinion bearings in front and the rear.
The early bird gets the worm,
84 Chevy K-20
Old 04-20-2019, 12:46 PM   #7
jdl71
jdl71's Avatar
Re: Eaton ho72
I know about the ratio mismatch. I’m trying to isolate some noises so I was just going to swap those chunks for a test and not use 4wd. Thanks
Psalm 23
64 C10
66 K20
Old 04-20-2019, 12:49 PM   #8
jdl71
jdl71's Avatar
Re: Eaton ho72
I’ve read the second one several times and like you said it’s mainly about Eaton vs 14 bolt. I haven’t seen the other thread before I’m going to read through it. Thanks
Psalm 23
64 C10
66 K20
