04-20-2019, 01:28 PM | #1 |
700R4 driveshaft solutions
I have a 70 longbed fleet. Right now it has a th350 with a two piece shaft. I’d like to convert it to a 700R4. Does anyone know a shaft that would be compatible? Two piece, 1 piece... Any advice on the appreciated. I don’t want to have to cut and balance if I don’t have to.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
04-20-2019, 02:33 PM | #2 |
Re: 700R4 driveshaft solutions
I've cut and re-welded more driveshafts than I care to count. I never had the need to balance.
YMMV
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
04-20-2019, 07:25 PM | #3 |
I could be wrong but your driveshaft may bolt right up. The 350 and 700 share the same slip yoke and I believe may even be the same length. My 400 was 2 1/2" shorter than my 700 and a different yoke.
04-20-2019, 07:50 PM | #4 |
When I converted my 68 longbed stepside to a 700R4 I had to have a special drive shaft made at a shop.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
04-20-2019, 07:57 PM | #5 |
04-20-2019, 08:08 PM | #6 |
04-20-2019, 09:59 PM | #7 |
Thanks all for the replies. I guess I was looking for a common solution. Like the driveshaft from a park avenue wagon is the perfect length, or something.
04-20-2019, 10:11 PM | #8 |
67-70 trucks came with a 400 trans. I don't believe the th350 came till 71. I may be off on the years but I do know they came much later. Also when you go to set up your 700 consider using bowtie overdrive's TV kit for your carburetor. It's a little more expensive but cheaper than frying a new trans.
04-21-2019, 12:33 AM | #9 |
The th350 and 200r4 are the same length The th400 and 700r4 are the same length. My 70 C20 came with a TH 350 trans
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
04-21-2019, 06:42 AM | #10 | |
04-21-2019, 06:47 AM | #11 |
Maybe its a 400, IDK, I just assumed it was a 350. Have to look.
04-21-2019, 11:30 AM | #12 |
I just swapped out my 400 for my new 700r4 and they definitely were not the same length. I cut my driveshaft down 2 3/4". My new yoke was a 1/4" longer than the old one. The 400 trans was 2 1/2" shorter than the 700 r4.
When you go to check your new trans be sure to check your pressures BEFORE you drive it. You can get the directions from the Bowtie overdrive website. |
04-21-2019, 11:37 AM | #13 |
Here is a link to there website. There is a lot of great info here.
http://www.tvmadeez.com/article/index.php |
04-28-2019, 05:22 PM | #14 |
This is actually quite simple. It depends on which th350 is in it, there is a long and short shaft. But at the end of the day it would have to be shorter if anything and not longer. Have it shortened & balances. Too cheap not to do it and guaranteed a smooth driveline
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
04-28-2019, 05:24 PM | #15 |
Thought I’d add this also
04-28-2019, 08:56 PM | #16 |
04-28-2019, 10:59 PM | #17 |
I just had the 350 in my 72 replaced with an early 700R4. The driveshaft needed to be shortened a little bit (either 1 1/2 or 2 1/2 inches, can't remember for sure). I dropped it off at the commercial shop that does lots work on large trucks and they had it ready to go the next day. It sure is nice having overdrive! I have to watch my speed on the freeway now as it is so quiet I don't realize how fast I am going!
04-29-2019, 07:39 AM | #18 |
Thanks all. I Feel much more confident about this swap.
