Old 04-21-2019, 09:18 AM   #1
Poppateez
Overdrive install
69 C10 1/2 ton sb stepside 250cc/373r; R10 BW overdrive; all wired up but can't connect the speedo cable; unverified but they told me the OD came out of a chevy pick; anybody got a clue?
Poppateez is offline   Reply With Quote
Old 04-21-2019, 09:24 AM   #2
geezer#99
geezer#99's Avatar
Re: Overdrive install
What you got for a connector?
Pics help.
Old 04-21-2019, 11:28 AM   #3
Poppateez
Original connector.
Old 04-21-2019, 11:34 AM   #4
jocko
jocko's Avatar
I'm not trackin, why can't you connect it? Is it just too short? Or is the square drive in the speedo drive bullet rounded out?
Old 04-21-2019, 12:38 PM   #5
Poppateez
I'm thinking the BW OD uses a different connector? or speedo cable? The OD works off a signal from the governor on the OD at 28 mph. If the speedo cable doesn't connect then the OD won't kick in. I can get the connector to thread on but it's not tight...wobble wobble turkey neck.
Old 04-21-2019, 01:03 PM   #6
kwmech
Looks like it will connect up. Sure it's turning from the inside?
Old 04-21-2019, 01:29 PM   #7
Poppateez
maybe just need a new speedo cable. sounds like it should connect but the speedo drive bullet is rounded out. going to the spring swap meet. never been. maybe find one there.
Old 04-21-2019, 04:48 PM   #8
jocko
jocko's Avatar
If it's rounded out, then a new one is required. If you just can't get it to seat, then it's helpful to have someone spin the speedo end of the square drive while you apply very light pressure at the trans connection until you feel it drop into the drive and then it's easier to screw on the cable retainer. If working solo, just get the retainer cap started, then go spin the speedo end of the square drive yourself - will be obvious if when it seats in the trans end.
Old 04-21-2019, 09:56 PM   #9
HO455
Post Whore
HO455's Avatar
It is likely that you will need a cable drive adapter to make it work. There are a half dozen different styles of speedometer drives. See below for an example.
https://transmissioncenter.net/shop/...mall-part-kit/
RIP Bob Parks.
Old 04-21-2019, 10:06 PM   #10
lutronjim
I installed a GM OD tranny from a 69 into my 70 C10. The cable worked fine.
The governor doesn't care if speedo is hooked up or not.
lutronjim is offline   Reply With Quote
