Old 04-22-2019, 07:16 PM   #1
cfan10
cfan10's Avatar
Cool New fuel pump, no sound
OK, I installed a new fuel pump yesterday cleaned all the gas lines, new fuel filter. Tank is in good condition but the old fuel pump dropped rust particles from the clamps. I'll maybe one day drop the tank and clean it, probably not since I cut a access to the fuel pump.
The new fuel pump doesn't prime and truck wouldn't start, checked battery with jumper it shows red, damn Walmart batteries! I thought even if the battery is really low wouldn't cause the fuel pump not to prime, the truck almost started a few times but I heard nothing.
Info:
91 suburban 5.7 tbi/700r4
As always many thanks in advance for the advice, it is greatly appreciated!
https://youtu.be/nicTjbM7vOE
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 04-22-2019, 07:18 PM   #2
undertaker72
undertaker72's Avatar
Re: New fuel pump, no sound
get full voltage and check for a good clean ground
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 04-22-2019, 08:23 PM   #3
sweetk30
sweetk30's Avatar
check for good ground from sender end to frame .
check for power to pump sender plug .
single red wire on relay at firewall for fuel pump is for testing relay . send 12v pos down it and check for pump run and voltage . if works then the relay is possible d.o.a or other problems .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
