Old 04-23-2019, 06:54 PM   #1
jdl71
jdl71's Avatar
Dim dash lights/headlight swicth
I don’t expect the dash lights to be like modern stuff but I would think it would be obvious they are on, and unless it’s pitch black it’s hard to tell. I’ve read about replacing the bulbs with led’s but I’d rather not do that. I’m suspecting the headlight swicth is the issue. I’m only getting about 9.5-10v at the panel lamp fuse when I turn it on and rotate to full bright. If I run a jumper from the spotlight fuse and give them a full 12v I can clearly see they’re on and would be happy with that level of brightness. My question is, is this “normal”, as in there is built in resistance in the switch to keep the dash lamps from getting a full 12v, or as I’m thinking, the old swicth just isn’t working as it should?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-23-2019, 07:01 PM   #2
AJC
Re: Dim dash lights/headlight swicth
What is your alternator putting out? Also ohm your switch. The rheostat in the switch should be around 0 ohms at full brightness.
AJC
AJC is offline   Reply With Quote
Old 04-23-2019, 07:08 PM   #3
jdl71
jdl71's Avatar
I was testing with the engine off. Ohming the swicth was going to be next step but wasn’t sure what it should be. Thanks
Psalm 23
64 C10
66 K20
Old 04-23-2019, 07:13 PM   #4
damnyankee36
damnyankee36's Avatar
Another way to check this is to jump the headlight switch at the red and dark green terminals. That bypasses the switch and sends full voltage to the dash lights. You can do this with the connector attached or disconnected from the switch. Actually, any voltage source connected to the green wire will accomplish the same thing.
damnyankee36 is offline   Reply With Quote
Old 04-23-2019, 07:17 PM   #5
jdl71
jdl71's Avatar
I pulled the dash light fuse and ran a jumper from the spotlight term and the lights got much brighter. The spotlight term had 12.3v or so.
Psalm 23
64 C10
66 K20
Old 04-23-2019, 07:18 PM   #6
AJC
I would also start checking your grounds. My interior lights were dim on my truck because it was missing the engine to cab ground. You still running the factory ammeter? I have to check if these trucks run a shunt or full power through the ammeter.
AJC
Old 04-23-2019, 07:24 PM   #7
jdl71
jdl71's Avatar
I’ve read that too. But since taking power from another source in the fuse panel makes them brighter, doesn’t that pretty much rule out everything except the switch?
Psalm 23
64 C10
66 K20
Old 04-23-2019, 07:25 PM   #8
damnyankee36
If applying full voltage to the fuse and the lights brighten then his ground is good.
It sure sounds like the switch. When you applied voltage to the fuse that's sending power through the gray wire directly to the lights. The other wire at this fuse is the green wire which goes to the switch.
But just to be sure if you apply voltage to the green wire at the switch that tests the entire circuit after the switch.
Old 04-23-2019, 07:30 PM   #9
damnyankee36
I wonder if the switch is not allowing the rheostat to completely turn all the way to full brightness. Can you turn on the dome light using the switch?
Old 04-23-2019, 07:31 PM   #10
jdl71
jdl71's Avatar
I had considered that there could be a resistance between the swicth and fuse panel but not tested yet. I guess my main question was shouldn’t the switch be passing full B+ to the fuse and it appears it should. That tells me where to look. Thanks.
Psalm 23
64 C10
66 K20
