![]() Join Date: Feb 2012
Glove box pcm with vintage air
Is there room to mount the pcm in the glove box with vintage air. I do not have the vintage air yet but need to mount the pcm and cant find any pics of that combo. the pcm would be standing up with the wires pointing to the drivers side with the pcm all the way to the right side of glove box opening. any info on this would be greatful
Re: Glove box pcm with vintage air
In my '84 I was able to put it in front of the VA unit. I had to point the wires downward though. Also had to cut the glove box down more then the template that they provide. It is very tight in there with all the ductwork. I had to place the fuse panel and TAC module behind the ash tray. Not ideal but it should be OK.
You should mount it temporarily until you get the VA unit. It is humongous. |
Depending on which pcm it may fit in a 67-72 with vintage air... but the entire glove box would be maxed out at that point.
