Making the best of a 12 bolt
The rearend on my ‘70 K10 burb is completely worn out. I have one out of a ‘72 also, but same deal. Mostly stock truck that gets mostly highway miles, so I don’t need anything special. I’ve looked at getting one with the same ratio out of a square body and moving the spring pads, but I may just be getting one that’s slightly less worn, although I like the idea of the bigger brakes. I may end up just taking the original to an axle shop and have them replace all the internals and then swap on the later, bigger brakes myself. But maybe there’s a place that sells a whole rebuilt unit? Again, this truck doesn’t do any Fall Guy stuff (80’s reference if you’re wondering) so a 12 bolt is fine. I was just thinking maybe someone else has been down this road already. Thanks.
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: Making the best of a 12 bolt
I think Moser makes entirely new car 12-bolt housings and everything. I haven't been brave enough to look at the price.
I would imagine they'll make one that will bolt into a C10. So it wouldn't be a truck 12-bolt but would probably be stronger after their upgrades. Most good axle shops could likely take your housing and make everything else new. I did it myself, but setting the pinion depth can take special tools. It definitely takes a lot of patience the first time.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
What do you mean by "worn out"?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
I looked at the Moser site and it does look like mostly car 12 bolt stuff. They are expensive but since the only usable parts on either of my axles is the housing and axle shafts, it’s going to be expensive either way. I’ve been hoping to stumble across something usable for a couple of years, but the howling back there says I’m out of time. Fortunately I have a very well-respected shop nearby.
That is what I am thinking. Replacing bearings requires a few special pullers but otherwise not a difficult repair.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Ok, case worn out. Egg shaped holes where cross shaft goes thru, gears worn and chipped, etc. Extremely high mileage. Worn out.
Search craigslist and the facebook marketplace. I picked up a great used diff carrier, side gears and ring and pinion for about $125.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Sounds like its time for a new limited slip diff of your choice, gear set, and bearing install kit. Have it all put in your existing housing. No need to over think this.
#9 | ||
"I ain't nobody, dork."
The "case" is the housing. The "carrier" holds the spider gears or limited slip unit (which the cross shafte goes through). You just need a new carrier and a set of gears and bearing/install kit.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#10 | |
The carrier is the part that holds the differential case. The Eaton axle has a removable carrier. The 12 bolt is a salisbury design with an integrated carrier.
#11 | |
They will make what ever rear end you want for your Chevrolet pickup, however you want it. A truck 12 bolt, a 9" F**d, a Dana 60, a GM 10 bolt 8.5. etc. AND make it a bolt in deal!!! It ain't cheap. FInd a differential specialist and have yours rebuilt, how you want it!!! |
