Old 04-24-2019, 06:19 PM   #1
Tom
driving is in my blood
Tom's Avatar
tail gate handle issue? 98 gmc
The tail gate handle to release the gate is crooked on my truck and some times I have to reach in and pull the left side release rod more because just using the handle doesn't pull it enough. The handle is not broken or flexing, and looks to be mounted perfectly strait. Anyone else have this issue? What was the fix?
Old 04-24-2019, 07:18 PM   #2
shifty
Questionable
shifty's Avatar
Re: tail gate handle issue? 98 gmc
You have one of these clips on each bar to the latch. (don't buy the one I linked, there are less expensive packs out there)
They're not bulletproof. They eventually can fail. I suspect the one may be bad on yours.
All you need to do to confirm whether this is the case with yours is to snap out the trim piece around the handle itself. Then watch the motion of things as you pull up on the handle.
I can't remember what attaches the metal bar to the latch plunger itself - there may be another one on the plunger/latch mechanism side you can't see. If so, you can only get to that by removing the latch mechanism on the affected side.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-25-2019, 09:25 AM   #3
95 S_Trucker
95 S_Trucker's Avatar
I’ve also had to bend the rod to make it a little shorter
95 S_Trucker is offline   Reply With Quote
Old 04-25-2019, 10:33 AM   #4
speedygonzales
speedygonzales's Avatar
It's usually the clips
Generally the length of the rods doesn't grow over time so if the problem is new, it's usually the clips that are on both ends of each rod. The clips can still be there but worn in the inside (pulling direction) of the rods.
When this happens, the rods have to move further than normal and sometimes appear to be short. That is, not pulling enough to open the tailgate.
The clips are available from a variety of sources in the help aisle from Dorman
https://www.oreillyauto.com/detail/b...e+Handle&pos=0
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 04-26-2019, 07:18 PM   #5
71gmcC15
71gmcC15's Avatar
Order a new trim peace to. Your going brake the clips that hold it in. Even if you think you whant you will. They are quite easy to brake.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
