Old 04-24-2019, 08:55 PM   #1
Missyblue
column advice old oem different year?
Hey I was wondering if anyone could advise me. trying to locate an oem column and looking for options. has anyone used a 1970's gm van column supposedly has tilt and key on dash still which would be cool. I can't seem to.find good info on when they switchswitched to key on column? and also what year the mounting to the dash really changed? like the idea of using an old column vs a $800 ididit and scared from what I have read on safety concerns on the other reproduced and possibly Chinese columns.
curious if you have used any 70's or 80 or 90s van or truck columns and found them fairly adaptable. also rreally want to keep the original steering wheel.
thanks!
Missyblue is offline   Reply With Quote
Old 04-24-2019, 11:13 PM   #2
popstand
Re: column advice old oem different year?
The 70’s Chevy van tilt column is the one to use. Not big and fat, and has a better shape than an Ididit.
That's what I put in my ’53. Mine had a ignition key but I removed it and filled the hole, put a later switch with key start in the original hole in the dash.
popstand is offline   Reply With Quote
Old 04-24-2019, 11:16 PM   #3
59chev
59chev's Avatar
70- 78 ish Chevy Van or 72 Chevy truck both work good. Parts are interchangeable between the Van Columns and the 72 Chevy Truck Column. They also fit in the stock Column Drop. I used a 78 Chevy Van Column in mine.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 04-25-2019, 08:18 AM   #4
Missyblue
See the old photo of mine during build.
BTW in the photo notice the speedo.
https://photobucket.com/gallery/user...eHAuanBn/?ref=
wow that does look like it belongs there. nice truck!! thanks for the info and photo. did you have to rebuild or do anything to your column?
Old 04-25-2019, 08:21 AM   #5
Missyblue
thanks for the info. I was looking at your build and such a cool story. I'm having to do alot myself and it's a steep learning curve so very inspiring haha. my 4 yr old daughter is helping too which is fun. did you have to rebuild or do anything to the column you used? I have found one thatbisna 78 and the van has 135,ooo miles on it.
thanks again. awesome truck!
Old 04-25-2019, 09:25 AM   #6
popstand
made up shaft from column to gear of '79 Nova subframe - would also work with original gear.
no comment on my speedo?
Old 04-25-2019, 10:05 AM   #7
Missyblue
sorry meant to...it's really neat. so you did a whole custom dash? what's mounted on the column? looks like another guests of some sort?
Old 04-25-2019, 11:02 AM   #8
Missyblue
oops sorry I just saw the '53 comment so I guess I'm missing your Speedo comment? sorry not familiar with all the the years and how they look. mines a 57
