Old 04-25-2019, 10:38 AM   #1
65btk
Oil and coolant mixed
I have a a inline 6 230 in a 65 c10. Was sitting since the 80s in a barn I was told. I got the truck running with fresh fluids. After a while of messing with it, the truck started shooting (pulsating) water out of the radiator with out the cap off. So I figured it was a blown head gasket. There was no coolant in oil or oil in coolant at that time. So I decided since the engine had good compression and I'm doing a budget build I would pull engine, clean every thing up with fresh gaskets and paint. Got every thing back together and fire it up. my new thermostat stuck shut an the engine over heated it while I was adjusting carbertor and timing. That resulted in coolant in my oil and oil in my coolant. I took the engine apart and it dont seem that the head gasket is noticeably blown. Did not see no cracks in cylinder wall or head. Any suggestion on where the are mixing at?
65btk is offline   Reply With Quote
Old 04-25-2019, 02:36 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Oil and coolant mixed
Did you do a compression test before you tore it down?...that woulda told you where to start looking..
I'm gonna guess cracked head if head gasket looks good...but it's just a guess..
How hot did it get when it overheated?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-25-2019, 09:14 PM   #3
65btk
No I already tore it apart. When I went to the cab to shut off engine the guage was coolant guage was pegged out on the H. Is there a common spot they crack?
Old 04-25-2019, 09:18 PM   #4
mongocanfly
Post Whore
Hard to say now....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-26-2019, 10:58 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Since it's apart... I'd have that head magnafluxed for cracks at a machine shop.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-27-2019, 08:07 AM   #6
YoungPup1977
I would have the block checked as well. The term budget build to me is doing it right if you don't have the money for the machine shop put it back where you found it.
YoungPup1977 is offline   Reply With Quote
Old 04-27-2019, 12:43 PM   #7
65btk
I will get some qoutes from the machine shops and wieght my options. Might be time to just invest in a 350.
Old 04-27-2019, 02:09 PM   #8
mongocanfly
Post Whore
It wouldnt take much machine shop cost on the 6 to justify going sb...
Mongo...aka Greg
RIP Dad
RIP Jesse
