A-Adam A-Adam
I have a 70 3/4 ton GMC. I am having a problem with Vapor lock. I have replaced the filter and fuel pump. I finally figured out that the fuel line from the tank to the pump is getting hot. The exhust pipe runs right between the starter and the frame. And it all gets very hot there. I figured out this was the problem by running it till it was hot and was starting to vapor lock then spraying water on the frame. It started pumping fuel great again after it was cooled.
I have I believe a stock 350 in it. No headers etc. I am considering rerouting the fuel line. But, I have never seen anyone else discuss this problem. Have you had the same problem? What did you do about it? If you have not had the problem am I missing something? It seems to me that if everyones truck is set up like mine they should all have the same problem. ![]()
70 3/4 ton GMC Camper Special |
My son, my joy.
You could reroute the fuel line. Or you could construct some kind of heat shield using pipe clamps and sheet metal.
Also, maybe the fuel line got mesed with and is just a bit too close to the pipe and bending it away just a few inches might do the trick. I'd have to go look at mine to remember how its routed. |
A-Adam A-Adam
The fuel line runs inside the frame rail. It is fastened to it with clips. I am also thinking of usins a heat shield.
Robert Olson Transport
![]() Join Date: Oct 2002
your setup creates too much heat fabricate some kind of heat shield and make sure the line is kept as far away fromt he headers as possible
A-Adam A-Adam
ttt
Wiseass secured himself a BAN
Get some aluminum foil and wrap it around the fuel line. Don't wrap it around tight. This should dissapate heat well enough to keep it from vapor locking.
its all about the +6 inches
By chance, do you have a fuel filter between the pump and the tank?
This can make vapor lock issues worse, and the more crap in the filter the worse the vapor lock can get. |
Many of us have headers along with the same fuel line setup without issues. I'm going with filter is in the wrong place or clogged.
A-Adam A-Adam
That is what has me stumped. I figure that everyone should be having thhe same problem. I don't have headers and the only fuel filter is a see through one just before the carb. And I have replaced that filter a couple of times.
A common place for a filter to be installed (I thought they were stock there but I was mistaken) is directly under the cab where the fuel line comes through the floor. I would double check that location for a filter.
If there is a filter between the pump and the tank, then as that filter gets clogged up and imposes a restriction, the fuel pressure drops in that section of line. The drop in pressure will lower the boiling point. (anyone remember the old pressure cookers that worked off this principle...actually the oposite principle) Another thing to look at is heat can be transfered pretty easily too. If you have a header pipe that is touching the frame, and the fule line is close by, the heat could be passed off to the fuel. It is odd that you are having this problem at this time of year. It is commonplace in the heat of the summer...but pretty much unheard of in november. |
