Old 04-26-2019, 10:35 PM   #1
70CHEVYBB
70CHEVYBB's Avatar
Fuel pump not turning on
Working on my first ls swap. I have a 72 i put a 5.3 in. It cranks over but fuel pump is not turning on. I have a psi harness on the engine and a boyds tank and pump set up. I have power to the fuel pump relay and have swapped the relay with another and still nothing. Any thoughts?
70CHEVYBB is offline   Reply With Quote
Old 04-26-2019, 10:44 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Fuel pump not turning on
Is it a intank pump?..do you have power at the pump?...if you have power there it's either wiring or pump
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-26-2019, 10:55 PM   #3
70CHEVYBB
70CHEVYBB's Avatar
It is a aero precision pump in the tank. The relay does not even click to send power to the pump
Old 04-26-2019, 11:01 PM   #4
ls1nova71
ls1nova71's Avatar
Have you checked all your grounds for being good and clean and tight?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-27-2019, 12:23 PM   #5
paul mora
Check the wiring to your relay if you have power to the relay and none downstream it is most likely wired incorrect. I would disconnect the the pump to be sure you have the wiring correct at the pump by removing it from the circuit. If it works with the pump disconnected go over your wiring to the pump or bypass the relay to see if it works
Pulatoy
paul mora is offline   Reply With Quote
Old 04-27-2019, 02:14 PM   #6
mongocanfly
Double check how your hooked into the fuse block.....switch on to #30 ...to the pump #87
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-27-2019, 04:24 PM   #7
ls1nova71
ls1nova71's Avatar
I've never had one, but doesn't a PSI harness come with the fuel pump relay already wired in?
Old 04-27-2019, 06:50 PM   #8
70CHEVYBB
70CHEVYBB's Avatar
All you have to do is add the power wire and the fuel pump wire. The instructions are very clear and simple. I tried it this morning and the pump ran with the key and the engine tried to start but then fuel pump quit and i lost spark. Very frustrated as i bought a new preprogrammed pcm from PSI when i bought the harness for a trouble free start up and no need to have someone else tune it. I have quadruple check all my wiring so it looks like a call to PSI and bring home a scanner from work monday.
