04-29-2019, 06:47 PM | #1 |
63 C10 gas pedal conversion questions
I'm starting to work on my 63 Fleetside project and I'd like to get rid of the mechanical stock linkage and get a drive by wire setup. I'll be running a 283 tripower with a 200r4 trans.
The location of the stock pedal assembly is in a weird place...it not flat on the floor but more on the side of the trans tunnel or should I say next to it. Anyone using a drive by wire setup? If so for what model year vehicles did they get it from??.post some pics too. They really help! Thanks in advance.. |
04-29-2019, 07:21 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 63 C10 gas pedal conversion questions
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-29-2019, 08:10 PM | #3 |
Moderator
So your getting an LS? Loosing the 283 and tri-power.
04-29-2019, 09:49 PM | #4 |
I probably should have asked if anyone used or knows of a pedal conversion that uses a cable instead of the stock linkage on my 63 C10. As mentioned,I'll be running a 283 with tri power and a 200R4.
04-30-2019, 10:59 AM | #5 |
Moderator
You'r probably wanting something like this?
http://67-72chevytrucks.com/vboard/s...00#post1383300 Or this?: http://67-72chevytrucks.com/vboard/s...d.php?t=530828
04-30-2019, 11:32 AM | #6 |
1965 C10 1967 Camaro 1998 C1500 2011 Colorado W/T |
04-30-2019, 12:56 PM | #7 |
I used a squarebody pedal, but it did not fit the best. I would use the 71-72 pedal if I did it again
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-30-2019, 01:09 PM | #8 | |
04-30-2019, 01:10 PM | #9 |
[quoted=The Rocknrod;8516594]You'r probably wanting something like this?
http://67-72chevytrucks.com/vboard/s...00#post1383300 Or this?: http://67-72chevytrucks.com/vboard/s...d.php?t=530828[/quote] Interesting.. Thanks for the links! |
05-01-2019, 02:11 PM | #10 |
here you go
05-01-2019, 03:44 PM | #11 |
05-01-2019, 05:26 PM | #12 |
Mine is a 65. It’s hard to get in a photo but it is above and to the left of the uneven spot
05-01-2019, 08:37 PM | #13 |
this was my old set up
here is my new no name pedal
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
05-01-2019, 08:48 PM | #14 | |
05-01-2019, 08:52 PM | #15 |
No issues with the pedal being where it is? Looks like a nice set up. I'm trying to find something closer to a stock look...but I'll keep looking. Have you seen anyone use the old stock pedal on a new cable set up??
