Ls swap with hooker manifolds
Tried searching this but with a 5.3 / th350/ 205 in stock location (trans and transfer case havent moved) will a set of hooker exhaust manifolds fit without modifications?
![]() Join Date: Apr 2006
Re: Ls swap with hooker manifolds
I have them in my swap but I have a 4l80 with the engine set forward. I have plenty of clearance. They look like they were made for it. I would think closer to stock they would fit even better based on how the frame tapers on mine. They set real close to the block for clearance.
Kirk 72 Blazer CST 4wd highlander Last edited by Blazerowner; 05-18-2019 at 08:29 PM. |
Thank you i went ahead and ordered a set.i will post a picture for future reference
Maybe this will help someone one day
Here’s mine
Kirk 72 Blazer CST 4wd highlander |
So I was under the impression that you cannot put a 5.3 in stock V8 4x4 location with a turbo 350 because heads will hit firewall. By the looks of this thread that’s false!? I’m at a spot now trying to decide if 4l80/advance adapters/tcase mods are worth it. I’m guessing no... thanks and sorry for the hijack! Looks like I’ll use these manifolds too.
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
I have not set my cab down yet so I hope doesn't have a issue
I’m not sure if it would fit in the stock location since I went with the 4l80e. The 4l60e should handle the 5.3l. I went with the 4l80 due to the power of the ls3.
| Bookmarks |
