![]() Join Date: Jul 2012
Dakota Digital LS swap oil pressure sender question
This has likely been covered but when not using the BIM and using Dakota's sending units how are you getting oil pressure reading to the pcm ? Dakota says their guages have to read their sender. Does this require a second oil pressure sender to be tapped somewhere either for it or the pcm ?
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438 |
#2 | |
Re: Dakota Digital LS swap oil pressure sender question
I Just used the sender that came with my gauges and, have had no problems.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
![]() Join Date: Aug 2018
I don't know what your sender looks like, but if it's like the sender that New Vintage provides with their gauge packages, you can buy an adapter from LSX Innovations that replaces your OEM LS oil bypass plate. There are a couple different configurations in terms of how many ports it comes with and I ordered mine from Amazon.
https://www.lsxinnovations.com/produ...rs-relocation/
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Post Whore
![]() ![]() Join Date: May 2015
The ecm does not need oil pressure input...all you need is the proper Dakota sender for your gauge...and if its npt sender then you'll need the metric to npt adapter..
Thanks guys, makes sense now
Nice looking truck! I used to have a real similar one. Whether or not the PCM needs the oil pressure sensor depends on what year your engine is, but I'm going to assume its a GenIII since you didn't mention otherwise, so if that's the case you don't need it. To install the DD sender you can either tap the bypass block above the oil filter or you will need an adapter to put it in the stock location. Be careful with aftermarket adapters because they are usually pretty thin and will snap off easily, seen it done several times. Or, you can do what I do and break off the plastic part of the original sender and drill and tap it for your sender. Super easy, cheap and wont break like the aftermarket adapters. There are pics in my thread in post #26. https://ls1tech.com/forums/conversio...-c-10-a-2.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
You need the original sender and hook up to ECM if you ever want to read gauges on a tablet with a Bluetooth scan tool for anyone who wants to do that.
