Old 05-02-2019, 09:32 PM   #1
Matt_50
Spring eye bolt
Ok so I have a checklist of things to do and I'm going through it one by one. Next up was making sure suspension was torqued and greased. I got to the passenger front spring eye bolt and realized it wasn't tightened up. It was sticking out a bit. I got to tighten it and it just spends. Same on other side.
It was broke in half on the inside! I haven't driven it or anything... Murphy's Law
I got the half out with the hex head. But it's the other half that's a problem. Looking at a couple bad old mounts, I realized it is threaded on one end. So the half a bolt needs to thread out the way it came but that can't happen. So I cut it flush and tried to drill it out.
My drill bits hardly scratched it. Please tell me a good quality bit can go right through it. Or help me with a better idea.
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-02-2019, 11:49 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Spring eye bolt
The spring bolt or shackle kits come with the bushing. So you could simply hammer the bushing with the bolt out.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-03-2019, 12:01 AM   #3
Matt_50
Re: Spring eye bolt
I tried to hammer it out. I then remembered that the bracket itself has a threaded hole on one end like in my second picture. One side it slides through then gets screwed into second side. I thought to cut it flush and drill it out carefully... but I need a bigger and better drill bit.
In hindsight I should have put a notch in the end so a flat head screw driver could possible spin in out the front. I don't really think it would have worked though.
So I need a very good quality 11/16 drill bit or a new bracket. I've made the mistake of buying cheaper bits and after 1/2 they start getting pricey for good quality. So I have been searching either or.
1950 Build
Old 05-03-2019, 08:13 AM   #4
Driver_WT
Driver_WT's Avatar
Re: Spring eye bolt
You can weld a nut onto the piece that is still in the bracket. Then heat up the bracket with a torch and then turn out the nut and the bolt half attached to it.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 05-03-2019, 08:31 AM   #5
Matt_50
Re: Spring eye bolt
It would have to be small and turn back through the leaf spring out the other side. I originally tried turning it to pull it through until I remember that wouldn't work because the shank of the bolt would just stop at the threads.
1950 Build
Old 05-03-2019, 11:52 AM   #6
paulspickupparts
Re: Spring eye bolt
You may still have to weld a nut on to the end of it . Drilling it out will be very difficult as the pin should be hardened. It will have to come out toward you as they do bottom out on one side of the spring shackle. I would heat the threaded area first . They often times have never been out and are froze up. Spray them for a few days with penetrating oil would not hurt anything. Good luck.
paulspickupparts is offline   Reply With Quote
Old 05-03-2019, 12:03 PM   #7
Matt_50
Re: Spring eye bolt
The picture is from the back side... where it is bottomed out. I need to go out through the spring right?
1950 Build
Old 05-03-2019, 12:34 PM   #8
paulspickupparts
Re: Spring eye bolt
Yes, the opposed direction of the threaded side of the shackle in the second picture.
Old 05-03-2019, 12:41 PM   #9
Matt_50
Re: Spring eye bolt
I might try to fix that bracket in second picture if I mess this one up lol
1950 Build
Old 05-03-2019, 12:53 PM   #10
paulspickupparts
Re: Spring eye bolt
Good idea . Almost all of them look like that . The usually show a lot of wear on the sides.
Old 05-06-2019, 12:17 AM   #11
Matt_50
Re: Spring eye bolt
Well found a couple front brackets for the cost of a drill bit... thankfully I already went through the trouble of cutting out rivets when I replaced the original that looked like something hit it.
1950 Build
