Old 05-03-2019, 12:07 AM   #1
69GMC2004
Active Member
Rack and Pinion conversion from a late model truck
I'm going to be doing a power steering conversion and was contemplating going rack and pinion. I'm wondering if anyone has used a rack and pinion form a late model truck in their 67-72?
Reason I'm considering this is because I already have a truck with the rack and pinion in it, that truck is the donor for engine and hydro boost unit I hope to use. I imagine it would be simpler to use all the components that were designed together.
Secondary question. For those running rack and pinion set ups with an LS engine, what have you found to work for headers/steering shaft combination?
69GMC2004 is offline   Reply With Quote
Old 05-03-2019, 09:13 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Rack and Pinion conversion from a late model truck
I cannot remember seeing hydroboost and R&P combination.
I didn't know they had similar hydraulic pressure requirements
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-03-2019, 09:01 PM   #3
AJC
A 2005 Chevy Express with a gvw of 7300 or less has a rack and pinion with hydroboost. So there must be others also.
Don't most run a Mustang or Thunderbird rack and pinon for there conversions?
AJC
AJC is offline   Reply With Quote
Old 05-04-2019, 08:04 PM   #4
69GMC2004
Active Member
You may be correct. Turns out I was thinking about 2 different trucks. My donor has conventional power steering and hydro boost.
The rack and pinion was on a different truck.
Old 05-04-2019, 09:16 PM   #5
Mike C
Mike C's Avatar
Personally, I think the rack and pinion is a poor choice for a truck. A lot of work for something that wears out faster than the recirculating ball setup..
And a heck of a lot more work. Just buy an aftermarket fast ratio steering box, bolt in on with a new pump and move on down the road.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-05-2019, 12:38 AM   #6
russellmarling
russellmarling's Avatar
I may be mistaken, but I believe the No Limit rack and pinion kit uses a late model Chevy pickup rack- so you might look into that...
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress)
'09 CTS-V M6
'03 Sierra SWB Z71
'82 Yamaha Seca XJ650R Turbo!
'04 Yamaha FZ6
russellmarling is offline   Reply With Quote
Old 05-05-2019, 11:09 AM   #7
Jrainman
Jrainman's Avatar
You are correct No limit does use a late model chevy truck rack with his kit ,but the rack is modified to his specs to work in conjuntion with the entire kit.
Jrainman is offline   Reply With Quote
Old 09-28-2019, 09:28 PM   #8
Madkidd007
Madkidd007's Avatar
Just throwing my experience out there. Late square bodies use metric fittings, and are 3.5 turns lock to lock, direct bolt on and has the same pitman arm splines
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
