Old 05-03-2019, 03:41 PM   #1
paulspickupparts
67 Chevy C50 80# Gauge Speedo Cluste With Glovebox
Good used speedo and gauge cluster removed from a very clean C50 . I checked and this does have the 80 # oil pressure. The speedometer and odometer both worked. I have not tested the other gauges. The truck did not have any additional gauges. There are tiny hairline cracks on the bezel from the screwhole down to the back of the bezel on a few of the screw holes. Still a nice bezel to use or restore. Orginal 67 Glovebox comes with it. $125 for what is shown by postal money order. Or $135 using paypal. Shipping will be additional . Usually runs about $35 . May be less if closer .
Note : This is from a C50 so if using in a pickup you will have to trim the bezel for the steering column. It is easy to do but so you are aware. Please message if you have any questions about this bezel. Thanks
paulspickupparts is offline   Reply With Quote
