Old 05-04-2019, 06:49 AM   #1
Dibdob62
Dibdob62's Avatar
Lowered now steering problem ???
I lowered my truck a few weeks ago 6"/4" then a few days ago I replaced all the steering linkages, Pitman arm, Idler arm, Inner and outer track rod ends but now the track rod arms are hitting the pitman and idler arms on full lock ?
I don't remember this happening after lowering it and before I replaced the steering parts. Has this happened to anyone else ? Is there a way to sort this ?
Dibdob62 is offline   Reply With Quote
Old 05-04-2019, 09:53 AM   #2
Rick Bollinger
Re: Lowered now steering problem ???
Looks like you have your drag link flipped. your tie rod nuts should be facing forward.
Rick Bollinger is offline   Reply With Quote
Old 05-04-2019, 10:49 AM   #3
JGRNTC10
The rod end holes are tapered. i didnt think you could get them on the wrong way....just my 2 cents
JGRNTC10 is offline   Reply With Quote
Old 05-04-2019, 11:14 AM   #4
Dibdob62
Dibdob62's Avatar
I think you have hit the nail on the head Rick thanks
Old 05-04-2019, 11:22 AM   #5
Rick Bollinger
Flipped end to end. The pitman arm was put on the idler arm hole which makes everything backwards.
Old 05-04-2019, 11:51 AM   #6
68is4me
68is4me's Avatar
Like the others have said, center link is flipped. Nuts should face the front. Put 90 degree grease zirks on the tie rods too, other wise they are almost impossible to grease.
Never mind the grease zirk statement you must have a different style of tie rods.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
