THM350 Gear Selector Lever on column
I have my 72 Cheyenne back on the road with new engine and new power steering pump.
But I am having an issue with the gear selector. When coming out of Park, the lever should be pulled toward the driver to allow access to Reverse or Drive. My lever does not pull rearward. It has no front to back movement. Attached picture shows the column. I can grab by hand the part closest to the front with the rod attached and move it toward the front of the truck, which I think is what should happen when the lever is pulled rearward.. It feels spring loaded in the column. Is the other part closer to the top of the column supposed to move, or is it stationary. Any thoughts on how to fix this? |
Re: THM350 Gear Selector Lever on column
I double checked all the adjustments in the manual, hooked it all back together and it takes more effort than it used to, but now the lever will pull back like it is supposed to. It say for 18 months while I was doing some work, so maybe the lubricant there is dry. I'll see if it loosens up with use and heat cycles.
![]() Join Date: Oct 2005
Easy fix. Drive out the pin that holds the shift lever in the column. Pull the lever out. Spray WD-40 or equivalent around the shift shaft inside the opening. Put the lever back in & put the punch in the hole instead of the pin. Work the lever back & forth till it frees up. Remove it again & spray some more. Put the lever back in & tap the pin back in the direction it came out.
George |
#4 | |
Thanks guys. I got it functioning but it is very tight. That should loosen it up.
Post Whore
![]() Join Date: Feb 2016
I had a similar problem. The gear selector has a metal bushing inside the bottom of the column and it was rusted. The rust caused the bushing to swell and prevent the selector from turning and from moving forward and aft so the dog will fall into the detent as it should.
I had to pull the column and completely disassemble the lower end. It took me eight hours to do it. I am pretty sure it could of been done faster if I had soaked the lower end in penetrating oil overnight before starting as the biggest task was removing the swollen bushing.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() ![]() Join Date: Mar 2016
I pulled the top of my column apart , cleaned all moving parts , reinstalled and spayed anti-seize into the shift lever hole . Now it works like new.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
