Old 05-05-2019, 08:15 PM   #1
QTRMOA
Guys w/ 4" lift, Can you measure from hub to fender?
So I bought a 72 Blazer with the lift already installed on her.
I'm trying to finish it out but and I can't figure out if I have a 6" or 4" lift.
It sits on 35" BFG AT which only measure 33 3/4".
It doesn't ride that great and seems to be pretty bouncy at times so I'm afraid I have a 6" lift.
Can anyone with a true 4" lift measure from center of your hub to the center of the bottom fender?
If you don't mind to include the brand of lift you have and size of tire.
I measured right at 28 1/4" with my lift from hub to fender.
QTRMOA is offline   Reply With Quote
Old 05-05-2019, 09:53 PM   #2
truckster
truckster's Avatar
Re: Guys w/ 4" lift, Can you measure from hub to fender?
I don't have a 4" lift, but using the measurements from this thread...
http://www.67-72chevytrucks.com/vboa...d.php?t=786050
...it looks like it might be a 6 inch lift.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 05-06-2019, 09:01 AM   #3
68panelman
68panelman's Avatar
My K5 has a 4" Rancho fronts with 35's and measured out to 26 1/2" at the locations you requested.
Hope this helps you
68panelman is offline   Reply With Quote
Old 05-06-2019, 09:00 PM   #4
Mike C
Mike C's Avatar
I have 4" Ranchos on my Jimmy as well. They are 35 years old and measure 26 1/2" as well as close as I can tell. With width of tire can't put the tape right against the fender.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-06-2019, 11:54 PM   #5
Blazerowner
Blazerowner's Avatar
Springs have a big factor on ride quality. The more leafs typically the less ridged they are. These trucks ride pretty bouncy anyway. Mine was bouncy with old wore out original springs.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
