Moderator
![]() Join Date: May 2007
I have a chance to pick up a 700r4 transmission for free, it is a non computer controlled unit. I’m not sure what it came out of originally but am wondering if I can use it in my 72 K20? Do I need a special 4x4 adapter to connect it to my np205 transfer case, or can I use the one from my th350 that’s already there? Thanks in advance.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
All about them K’s
![]() Join Date: Jun 2014
Re: 700 r4 in a K20?
There’s a few ways to skin this cat. The first is a shortened transmission output shaft that will then let you use the th350 adaptor to your 205. The second is a spacer that goes between the adaptor and the transmission that lets you keep the stock Kcase 700r4 output shaft. If your going to go thru the tranny use option 1. I looked into this a year or two back so this is just the gist of it. If I remember right you may have to move the motor forward because the 700r4 is longer than the th350. Don’t quote me on it though.
I was in your neck of the woods last month in my Camaro. The freeway can be pretty fun with 400hp and a 6 speed. If I was in my K20 with no overdrive, not so much. It’s not that I worry about the engine speed or anything like that, I just don’t care to go 80-90 in that beast.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 05-06-2019 at 08:11 PM. |
Yes, you move engine forward so the transfer case stays in the same place so the driveshafts can go untouched.
![]() Join Date: Oct 2009
If trans is a 2WD unit, need the shortened output shaft HERE
Original K-case is slightly stronger because of a 6-bolt torque converter cover, but unless you're going baja, probably not necessary. Torque converter cover bolt holes may be a clue - I think if 2WD, there may only be 4(?) K-case had 6 I believe. EDIT: I believe doing the output shaft swap and moving the engine fwd as Tim mentions is the preferred approach. Last edited by jocko; 05-06-2019 at 08:34 PM. |
Moderator
Sorry, I should have specified the 700 is a 2wd transmission. Thanks for the input so far everyone!
![]() Join Date: May 2017
Did this last year
All correct so far You need an output shaft installed for a 4x4 You can use a stock one with advanced adapters , adapter Or a modified shaft and a 350t adapter Then move motor forward 2" Also will need the presure cable and carb bracket and a lockup kit There are many out there Have fun Having overdrive is the only way to go imo |
I've done it too and used the AA output shaft.
Things I learned: my factory 4x4 fan shroud no longer fit the coolant hoses had to be modified my A/C lines had to be modified I had to move the shift linkage forward on the frame I notched the front crossmember for crank pulley clearance The transmission pan is really close to the front driveshaft but clears possibly because I have a 2" lift The exhaust pipes had to be lengthened Otherwise I would do it again ![]()
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
