05-06-2019, 02:59 PM | #1 |
are these 4x4 v8 engine mounts
bought a 1969 k20 with no engine. the prior owner cut the engine cross member out. I am looking to find out if the engine mounts are small block v8? the tag in glove box says the truck was built with a 396 cid but who knows what the prior owner had in the engine bay. can anyone help id the mounts in the photo please? I have 350 I want to put in it. thanks
05-06-2019, 03:11 PM | #2 |
Re: are these 4x4 v8 engine mounts
Correct me if I am wrong, guys, but I don't think any Ks from this era came with BBCs . . . .???
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
05-06-2019, 03:12 PM | #3 | |
if the 396 SPID and glove box go with the chassis, then the mounts in there may still be BBC, but the 4wd components would have been added.. if the SPID and glove box are not from the chassis and it's a factory K frame, the mounts would have been SBC if factory V8 equipped.. some dimensions will likely need to be compared to be sure, someone should be along soon with those.. good luck!
I started out with nothing - and I still have most of it |
05-06-2019, 03:42 PM | #4 |
killer bee may be right. the cab has been replaced. so option tag would be wrong. but the guy I purchased it from told me it had a big block. you know how people say things when trying to sell a truck. I just hope I can put my 350 in it. I will try to attach a photo of option tag.
05-06-2019, 04:03 PM | #5 |
previous owner may have bought it with cab swapped and didn't know the difference..
either way, may be to your advantage if it pans out to have had a SBC let this thread soak for a day or so and the guys that know how to ID the different mounts will help you out.. good luck!
05-06-2019, 06:37 PM | #6 |
All about them K’s
Yes they are v8 4x4 mounts.
From my K20. You might be able to find the lower part of the crossmember from the parts board.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
05-06-2019, 07:23 PM | #7 |
thanks 57 taskforce
05-06-2019, 07:31 PM | #8 |
These were in 72 K5 Blazer 350/350....Looks the same to me.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
05-06-2019, 08:31 PM | #9 |
Here is a picture of the cross member
05-06-2019, 09:36 PM | #10 |
awsome guys, thank everyone for contributing to help a form member in need.
