05-06-2019, 07:20 PM | #1 |
Radiator support
1950 3100, stock frame.
When I got this truck the front sheet metal was only partially assembled. Anyways there were two core supports each one is missing pieces. One mounts in the middle, one in two spots. Does it matter which one I use? And if I used the one where it only bolts in the middle... will the sheet metal rock side to side?
1950 Build |
05-06-2019, 07:22 PM | #2 |
Re: Radiator support
Both are missing support rods.. the X. And one is missing top piece and one is missing a bottom mount.
1950 Build |
05-06-2019, 10:38 PM | #3 |
The firewall brace rods probably prevent side-to-side rocking. And all those fender-to-cowl bolts.
1951 Chevy Panel Truck |
05-06-2019, 10:46 PM | #4 |
I have those rods, from pictures I've seen though the support should have inner braces and a top bar right?
1950 Build |
05-07-2019, 12:00 AM | #5 |
Here is what your rad support should look like. There is also a welded on tie bar going across the top that I made bolt in so it's not on there. The one you have leaning on the tree has that tie bar still welded on. A lot of them were removed to put motors in easier. Which is why I made mine bolt in.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-07-2019, 08:16 AM | #6 |
My 50 has the 2 bolts on the bottom.
I had to remove the X to fit the condenser for a vintage air setup. Radiator adds a lot of stiffness to the support. If I was doing the middle only one I would shim pads on the other two holes. That support plays big time in the alignment of the front sheet metal.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
05-07-2019, 08:20 AM | #7 |
I was wondering about usingvsome kind of shim or cutting some rubber for extra cushion but didn't see anything like it in the catalog.
1950 Build |
05-07-2019, 11:32 AM | #8 | |
Brian
05-07-2019, 11:52 AM | #9 |
I havebth3 little pad for in the middle. Do I need cushions on either side too?
1950 Build |
05-07-2019, 12:22 PM | #10 |
I think I misunderstood. Ok, so two bolts are in the center on one and the other support has one bolt hole on either side. On my crossmember it has all the holes as if it can take either support. Are they interchangeable? I know sheet metal alignment can be finicky.
The catalog looks like it calls for a 1950 to have one like MARTINSR. The one I have is missing one of the ... feet?..Would some thick washers work on that one side?
1950 Build |
05-07-2019, 01:20 PM | #11 | |
I actually have the rubber gasket in my parts box from the old rad support that I had with the single bracket in the middle, it was the original off my truck which is a '48. This rad support I got at some time (don't remember how, damn it sucks getting old) and it's the later one with the two brackets. Brian
05-07-2019, 01:29 PM | #12 | |
The later rad support with the two brackets also has a reinforcement inside making the bottom stronger. Brian
05-07-2019, 01:37 PM | #13 |
Thanks for clarifying. I'll make a spacer for that one side. I'm pretty sure I have some scrap 1/2 steel...
1950 Build |
05-07-2019, 01:43 PM | #14 | |
Brian
05-07-2019, 01:57 PM | #15 |
I'm not sure what you mean.. could I not make another mount out of scrap or even a few thick washers?
1950 Build |
05-07-2019, 02:26 PM | #16 |
Yes you can build a replacement mount.
Washers would work, but I would rather have the larger surface area like the original. The only reason for the gap between the radiator frame and mounting pad is so you can get a wrench in there to tighten it. Hard to do from the top with a radiator mounted. You could use a carriage bolt in a slotted retainer inside the u channel of the core support and then just add spacers or just weld a bolt to a square that fits in the u channel to keep it from turning. You will need to adjust the core support position when aligning front sheet metal Also truck mud flaps work good for replacement rubber pads.
05-07-2019, 02:28 PM | #17 | |
Nope, you don't need to get a wrench in there because it used a carriage bolt. Brian
05-07-2019, 02:42 PM | #18 |
I guess my core support has rounded out from wear. Needed washers there.
The frames holes where L shaped not slotted anymore. All fun when trying to align everything.
05-07-2019, 04:13 PM | #19 | |
Yours may have been drilled out for a larger bolt or something like that too. It has been around for 70 years a lot can happen. Brian
05-07-2019, 04:16 PM | #20 | |
Brian
05-07-2019, 04:49 PM | #21 |
I'd have to go out back and look. The one with the two bolts in the center goes with the 47/48 cabs with the center mount in the rear while the one with the two spread mounts goes with the cabs that have the shackles on the sides of the frame.
Lazy mechanics were normally the ones who cut the top piece and the X brace out and didn't put the back when they replaced the engine. Some engine swap guys cut them out to slide the radiator forward a tad then the radiator usually springs a leak due to the stress from the front end flexing.
05-07-2019, 05:05 PM | #22 | |
Brian
05-07-2019, 06:00 PM | #23 |
I think they were looking at guys driving them across rough fields and paths where the frames flexed a bunch and needed the cab supports to have the movement in them.
My 48 had the center mounted support on it when bought it that was hacked up by a previous owner.
05-07-2019, 08:20 PM | #24 |
Thanks for the input guys. I came home and cleaned and painted my other support. I'll figure out a spacer when I mount it..
Rubber and shims between support and frame and a rubber piece under and then a nut?
1950 Build |
05-07-2019, 08:36 PM | #25 | |
Brian
