Old 05-07-2019, 05:17 PM   #1
jabborabbo
jabborabbo's Avatar
Rochester B woes....
In an earlier thread I asked about the bowl to horn bolts loosening...I have a new problem....
I torqued the bolts to 70 in-lbs a few days ago - checked them yesterday and they needed a bit more torquing to get them to 70 in-lbs...but...one bolt stripped before it got to 70 in-lbs. I assume the bowl threads are what stripped - should I have heli-coils put in the bowl bolt holes, or should I (hopefully) find an NOS bowl?
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is online now   Reply With Quote
Old 05-07-2019, 08:01 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Rochester B woes....
If you don't mind having a nut showing instead of a screw head, you could put a stud in that hole with JB Weld to fix it in place. There may be a couple of threads that aren't stripped near the bottom of that hole that would also help fix it in place.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-08-2019, 12:20 AM   #3
jabborabbo
jabborabbo's Avatar
A threaded stud slathered up with JB Weld in the carb body with a nut holding the horn would be a heckuva lot simpler than a heli-coil! Thanks!
