Old 05-08-2019, 01:32 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Rochester carb. rebuilder?
Anyone know if Bob Stone is still in business? I can't locate a contact for him outside of personal venues.
Found a business that goes by "carb. doctor". He's in Canada, so the added expense. Nice guy and helpful too. He offered to set me up with a complete divorce choke. OT: I wasn't sure that would work with ceramic coated high heat parts, which reduces surface temp. He thinks so long as I got the stove pipe and the crossovers are open a divorce choke should work under reasonable winter conditions. This is a Nevada garage queen anyway. I'm still on the fence though, electric is a sure thing, a divorce choke is vintage
Other than that, any other carb. builders recommended? Small business types preferred. Thanks.............
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 05-08-2019, 05:56 AM   #2
Re: Rochester carb. rebuilder?
I've dealt with a local business for all my carb, starter, and alternator needs for years. But as far as a business on the national scale to suggest I would say Carb Doctor. I thought they were in PA, though. I understand they do a great job of building the carb for evilethanol exposure.
Old 05-08-2019, 12:54 PM   #3
MJN
MJN's Avatar
I would contact Quadrajet Power LLC, they're out of Texas. They rebuilt my Quadrajet and have great customer service too. https://quadrajetpower.com/
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-08-2019, 07:47 PM   #4
71CHEVYSHORTBED402
I had the impression Carb Doctor was in the USA as well, but Rusty (Canada) is the only one I can locate under that name. To Rusty's knowledge he's the only business on the web that falls under that label.
Say Tim, another question. I'm losing the external voltage regulator, any suggestions for a replacement that's internally regulated?
________________________________________________________________________________________________
Edit: For what it's worth, here's Rusty's response. I don't know what a M4ME choke is yet. Sounds like 4MV is a divorce choke. I may have been wrong about the crossover, don't know what a "crossover choke" is, though I think he means the crossover in the intake. Be a twist if a divorce choke actually worked better because of ceramic coatings.
Hello,
This is Rusty (redacted). Over the years there have been a few Carburetor Doctors. I thought I was the last one, online at least.
Briefly, the best set up to use depends on which carb # you have and which manifold you're using. Ceramic coatings help retain heat inside the exhaust, which helps the crossover choke. The lack of a heat riser impacts the choke. In any case, for anything other than full-out winter operation the 4MV type choke would be fine. But it depends on which carb you're going to use.
The simplest solution is a late style M4ME electric choke carb. Out of the box, this carb would work well:
http://carburetordoctor.com/carbs/A246.html
Restoring your 7041209 would cost $375, choke parts to fit a 1971 cast intake would run about $75. Time required for the restoration is around 8 weeks or so.
Regards,
Rusty
Tony
Old 05-08-2019, 08:09 PM   #5
geezer#99
geezer#99's Avatar
Do you mean this guy.
https://carburetor.ca/
As for your divorced choke working in cold weather. I used them for years before electric ones came out. Good down to 40 below. Might of had to fine tune them a bit. You can’t expect them to just bolt on and work perfectly.
And remember the dollar difference. You’re gaining 30% on your buck.
Old 05-08-2019, 08:20 PM   #6
rsavage
rsavage's Avatar
Cliff Ruggles is about the best in the business for Qjets
https://cliffshighperformance.com/
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-08-2019, 08:56 PM   #7
Tiger Joe
Lars. He is a qjet guru
Tiger Joe is offline   Reply With Quote
Old 05-08-2019, 11:30 PM   #8
71CHEVYSHORTBED402
Yes that’s the dude out of Canada. You lost me on gaining 30%.
Very cool...I've heard of him.
Lars?
Tony
Old 05-08-2019, 11:44 PM   #9
geezer#99
geezer#99's Avatar
The exchange rate.
You buy a carb for 300 bucks Canadian, you pay 200 US bucks.
Here’s Lars.
https://www.digitalcorvettes.com/for...ad.php?t=88376
Old 05-18-2019, 11:44 PM   #10
71CHEVYSHORTBED402
The exchange rate.
Here’s Lars.
Thanks Geezer. I think he charges USD only, USA and Canada. I read some of Lar's info., interesting guy.
Tony
Old 05-19-2019, 03:09 PM   #11
newbraunie
newbraunie's Avatar
This shop rebuilt a Rochester 2 barrel for me a few years back. Did a nice job.
Carburetor USA
http://www.carburetorusa.com/default.htm
This might be the one Special K was referring to in PA.
1971 C20 LWB Cheyenne 396/TH400
2017 Chevy SS - Holden conversion
2015 Chevy SS
2013 Acura MDX
newbraunie is offline   Reply With Quote
Old 05-20-2019, 05:24 PM   #12
AZ Chev
AZ Chev's Avatar
Bob Stone- 267-467-6018
Located in Pennsylvania
AZ Chev is offline   Reply With Quote
