Old 05-08-2019, 11:11 AM   #1
demian5
demian5's Avatar
Two position radiator mounting, I like it!
Finally started addressing a fan shroud for the radiator. My main issue was that the top hose was so close to the fan it was almost uncomfortable. I decided to look at the mounting of the radiator (I have never had any issues with it so never looked) and low and behold, there are two sets of holes to mount it!
I was not only able to raise it up enough to get the fan away from the hose and the shroud on comfortably, but also install the 3 bolts that it was missing attaching it to the core support!
Win Win!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-22-2019, 08:50 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Two position radiator mounting, I like it!
Win Win!
I like to be of Help this is to help if you have not Fixed your Brass and copper Radiators You can go to your local Radiator shop and have them Put a small snout so you can put the 1967 327 upper radiator hose on it it works out so much better an if you're running the
Edelbrock alum intake manifold. You can run your temp sending switch on top of the intake. I like the straight out top radiator hose fitting do not use the one that curves to the left them are made for the 1969 and above trucks. I like running 1960--68 chevy small block have a look
stsalvage is offline   Reply With Quote
Old 05-22-2019, 08:54 PM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
that was used on 1972 it makes for better fitment and cleans up your engine bay Now this is for the 1965 C20 Radiator hose placement
Old 05-23-2019, 11:29 AM   #4
demian5
demian5's Avatar
Thanks for the tips. I have it pretty sorted and will post pictures after I get the shroud mounted.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-24-2019, 08:24 PM   #5
Ken Cook
Ken Cook's Avatar
This is why I read all of these threads.
Two different people with priceless info.
I am about to pull my straight 6 and install a long block crate engine. I don't have any of the accessories or mounting brackets yet. So I will be addressing this soon and now know about different hoses and different mounting positions for the radiator.
Thank you both for the info!
Ken Cook is offline   Reply With Quote
Old 05-25-2019, 05:31 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Be careful, one of the posters posted info on a 67-72 which has a different radiator that ours.
