05-08-2019, 02:19 PM | #1 |
originally spring under or spring over?
you guys are extremely knowledgeable. my (truck new to me. driving it some every day) has the rear dif over the axle. was it changed to over or was it originally spring under?
05-08-2019, 05:29 PM | #2 |
Re: originally spring under or spring over?
Spring over.
HTH |
05-08-2019, 06:55 PM | #3 |
And under on the front.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-08-2019, 08:22 PM | #4 |
thanks guys. it looked all stock.
05-08-2019, 09:11 PM | #5 |
What model are we talking about here.
47/55.1 3100 had the rear axle above the spring the 3/4 ton had the rear axle under the spring. 55 second series through 59 pickups all had the rear spring above the rear axle. All I beam axle trucks came with the springs on top of the front axle.
05-09-2019, 09:38 AM | #6 | |
Brian
05-09-2019, 10:37 AM | #7 |
mine is a 51. Gmc
05-09-2019, 12:40 PM | #8 |
On the 51 GMC 6 lug is spring under the axle. 8 lug is spring over the axle.
GMC had both short 116 inch and long 125.5 inch wheelbase half tons where Chevy only had short wheelbase half tons. 1/2 ton springs are under the frame rails 3/4 ton springs are mounted on the sides of the frame rails.
05-09-2019, 04:12 PM | #9 | |
