Old 05-08-2019, 03:16 PM   #1
MARKDTN
Vortec serpentine system on early block
I have most of a Vortec ('98) Serpentine system that I am thinking of putting on my early block. I want a better a/c compressor. I see that a Vortec water pump is different than an early style because it does not have the bypass hole on 1 side that the earlier pumps have. Can you use a TBI water pump with a Vortec setup? I know I need a reverse rotating pump. I have an electric fan so I don't care about that part. Any experience with Vortec accessories on early blocks?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-08-2019, 08:20 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Vortec serpentine system on early block
http://67-72chevytrucks.com/vboard/s...d.php?t=468729
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-09-2019, 09:24 AM   #3
MARKDTN
That is a TBI setup. The Vortec setup has a Compressor on top of the engine that bolts vertically to a bracket. I THINK that a TBI pump should work with Vortec brackets. The Crank pulley appears to be similar which should mean that the water pump pulley will be in the right place. Guess I just need to mock it up and see.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 05-10-2019, 11:39 AM   #4
Big Kev-O
Big Kev-O's Avatar
You also have to consider the timing chain cover/tab. The timing chain cover on those is plastic and may differ from your existing cover. The serp brackets & accessories may interfere with your ability to see the timing tab on your old gen cover. I can take some pictures if it helps.
IIRC when I installed a cam in my 98 vortec block I wanted to get a metal timing cover but it was not an option due to the serp belt brackets.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 05-10-2019, 11:45 AM   #5
Big Kev-O
Big Kev-O's Avatar
One more thing, I used a rebuilt compressor despite many threads advising to use new GM. My rebuilt is loud!
Old 05-10-2019, 03:40 PM   #6
MARKDTN
I am trying to put Vortec (1996-1999 5.7 and similar years 4.3)accessories on a '90 Corvette TPI 5.7 block. I don't have the Corvette serpentine setup, I bought the engine without it. So I don't have the plastic timing cover. My dilemma is the water pump. A Vortec water pump has 4 bolts with each pair of bolts has a water hole between them. Prior to that there are the same 4 bolts with water holes between them plus a bypass hole below 1 of the bolts (Vortec uses an external bypass). So Vortec blocks and pumps are very similar but if not used together there will be a water leak where the bypass has no seal. So what I was hoping was that I could use the Vortec accessories to get the latest compressor and use a TBI water pump that will mate to my block and have the correct reverse rotation. Looks like I can also more easily adapt my CS144 alternator where all the TBI serpentines have an unreliable (IMHO) CS130 alternator. I can't see where anyone has done this, but I can't be the first. Thanks for the advice so far.
'83 K20-TPI
'73 C10
'14 Suburban-DD
