05-08-2019, 09:05 PM | #1 |
1970 GMC 3/4 ton Axle Stamp Info?
Anyone have info as to what my diff gears are with the axle
stamp? My truck is a 1970 GMC 3/4 ton. The stamp reads.... 58 OC1 603051 6 5 19 70 A7 |
05-08-2019, 10:34 PM | #2 |
Re: 1970 GMC 3/4 ton Axle Stamp Info?
Most 3/4 ton GMC trucks had Dana 60 rears. If yours does, if no one has removed it, it will have a tag between two of the diff cover bolts that has the ratio on it.
Gotta' love Dana for doing that and you have to hate PO's for removing it...
05-08-2019, 10:48 PM | #3 |
BOM 603051-6 =1969-1970 coil sprung rear, 4.10 gearing, with a power-loc
05-09-2019, 12:23 AM | #4 |
It does still have the tags. I’ll check tomorrow to see what the is stamped on them.
05-09-2019, 01:10 AM | #5 |
One tag will say limited slip and the other 4.10
