05-09-2019, 02:52 AM | #1 |
Fuel tank relocation question
I'm wanting to do a fuel tank relocation to a 61 GMC short bed step. The only kit I can see online for the 60-62 is a welded alloy one with a bed fill. What have others out there used or can the 63-66 kits be easily modified to fit?
Thanks |
05-10-2019, 10:39 AM | #2 |
Moderator
Re: Fuel tank relocation question
There is a write up here about a 69 tank being wider that a 66 frame. May work for the 61's? - http://67-72chevytrucks.com/vboard/s...d.php?t=448386
Also - http://67-72chevytrucks.com/vboard/s...d.php?t=370496 There is a whole conversion thread here - http://67-72chevytrucks.com/vboard/s...d.php?t=558629
05-12-2019, 02:01 AM | #3 | |
05-12-2019, 03:59 AM | #4 | |
05-12-2019, 08:45 AM | #5 |
Moderator
There are people on this site who have the frame dimensions info, I do not. If they see this thread your golden. If not keep bumping it.
05-12-2019, 10:21 AM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
The difference is 60-62 are 8” wider than 63-66
I believe it’s 34” and 42” but I’m not sure if that is outside or inside measurement
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-12-2019, 11:47 PM | #7 |
60-66 Nut
Those are the outside frame rail measurements. The '63-'72 frames have room for a tank 26.5-27" wide inside the rear frame rails.
05-13-2019, 11:56 AM | #8 |
Thanks Captn, I’ll make a note.
05-14-2019, 02:40 AM | #9 |
Thanks for that, I've got a '60 with an under bed tank but I can't for the life of me figure out what its from.
Good to know that the 61 will have a little more wiggle room to fit a tank than the '63. |
05-22-2019, 08:20 PM | #10 |
Scrapper 1
I've tried to talk to some of these guys about the french door access. Then i ask why can't you fill from Both sides of the tanks you know what hassle it is when your running on empty and every one4 is on the driver side is full. But if you had a french door on either side of your truck it would make filling your truck so much more easier. To me it would solve most of your problems at the Pump.
