Old 05-09-2019, 09:01 AM   #1
Matt_50
Accessory brackets
Can you guys double check me on these?
I think I'm missing the lower alternator bracket too. Got a picture?
350 motor, v belts, LWP, came out if 84 c10.
I think the bracket on the right in the picture is upper alternator and the left one is upper a/c? Do you guys know the bolt sizes and if I need washers?
I thought I was going to go serpentine belt route but I have had bad luck, people either want me to take the whole engine for like 300 bucks or they are missing brackets.
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-09-2019, 09:37 AM   #2
Matt_50
Re: Accessory brackets
I do not have a smog pump. I found two pictures of lower alternator brackets that look the same except one has a little extra to it with another bolt location and I'm guessing for smog pump right?
The smaller one is all I need to find?
1950 Build
