Old 11-28-2003, 11:55 AM   #1
maniago
C10 Rear suspension question
Oops I posted this in the E&D section by mistake.......I'll try to make this short, tho its a puzzle. Background: new to my stable is an abused '65 C10-Short Fleet. Driver side wheel base is 114.25" and passenger is 115.5'. Been hit in the front drivers corner many years ago and also rebuilt many years ago.....frame has no apparent damage back from the front a-arms (ie its straight and no popped rivets). Cab is on the frame in the original bolt down location and is straight (doors don't bind). Trailing arms are not bent, and measure the same length, are mounted in the right locations on the axle, but the whole axle assembly is shifted about 3" to the driver's side - trailing arms reflect the angle shift at the front mount (maybe 2 or 3 degrees - hard to estimate) and front end bushings on the trailing arms show long term "offset" wear.
Since everything rear end related is straight and in line the only thing I can come up with is that the panard bar (stock) is somehow too short and is forcing the axle to the side, thereby shortening/elongating the wb - BTW this is a '63 axle with the welded panard bracket vice the '65 carrier stud mount (according to the '65 Chevy manual sup). Questions: Can/should '63 axle cause this problem in '65s? Is the frame end panard mount on '63&'65s the same? If these are not issues, what is the correct center to center length of the '63 panard bar vice the '65 bar? Am I crazy?
Thanks for any help. Mick
maniago is offline   Reply With Quote
Old 11-28-2003, 12:44 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Contact IRONBUTTLCMC for this question. He just went through the hell you're describing on his truck. He's the expert on this area.
Old 11-28-2003, 05:52 PM   #3
maniago
Ok done. Thanks TxF - hopefully he'll have some good words. Cheers Mick
Old 11-28-2003, 06:06 PM   #4
rodnok1
rodnok1's Avatar
Measure the panhard bar, 24 inches is for the intergal mount and the 27 inch is for the type that welds on axle.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 11-28-2003, 10:14 PM   #5
maniago
Thanks - now I've got something to work with.
Anyone know if someone makes an adjustable p-rod for this (must be someone with all the slam projects out there), or do I have to fire up my smoke-wrench?
Old 11-30-2003, 10:08 PM   #6
68LSS1
68LSS1's Avatar
60-64 27" or 65-72 24" . the first link is the picture the second is to their catalogue.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
