Old 05-10-2019, 10:59 PM   #1
Whamp48
Junior Member
Over cammed 402
I have a 402 bbc in '72 Cheyenne Super. I've had it running a few times, but it never seems to run very well. I'm thinking whoever put it together was thinking more about power than usability. Do any of you guys know what cam, lifter, valve springs, carb and intake combo will work best for an everyday driver? I don't mind a little upgrade to maybe 350hp, but I don't want something that has to idle way high and has a tough time making enough vacuum to be usable. Thanks in advance for any suggestions......Warren Hampton
Whamp48 is offline   Reply With Quote
Old 05-11-2019, 08:18 AM   #2
engineer_gregh
engineer_gregh's Avatar
Re: Over cammed 402
I'm running a Comp Cams High Energy 268H kit in my 71 402 and I'm happy with it. You might like the 260H kit if you want a smooth idle. I would suggest calling Comp Cams tech support line and discussing it before buying either.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 05-11-2019, 08:24 AM   #3
Whamp48
Junior Member
Re: Over cammed 402
Thank you, Greg.
Old 05-11-2019, 08:58 AM   #4
geezer#99
geezer#99's Avatar
Re: Over cammed 402
possibly not the cam!
Could be the tune.
What carb, what distributor, what intake, what exhaust?
A little tuning could save you a chunk of money.
Old 05-13-2019, 08:17 AM   #5
Whamp48
Junior Member
Re: Over cammed 402
Thanks, Geezer.....I really hate to do anything to this engine. The truck itself has been a nightmare, with just about everything that's possible to be wrong being wrong. I put a new distributor, rebuilt quadrajet from National, one rocker was broken. Ran better, but still don't suit me. It's supposed to be newly overhauled, and appears to be. I'm the third owner since it was all partially put together. I've been suspicious of the cam since I've had it. The fellow I got it from told me it has a "big" cam, but I don't know the specs. So the only solution I can see is removing the cam and replacing it with one that will be suitable for a driver. Then if the heads have double or triple springs, they'll have to be replaced with springs that will work with the cam I get. I'm leaning toward the Comp 260H or 268H Greg suggested. I don't want a racer, just a good usable, driveable truck. Whew, don't I run on???
Old 05-13-2019, 10:15 AM   #6
geezer#99
geezer#99's Avatar
Re: Over cammed 402
Sell that lumpy cam 402 and get a mild 454.
You’ll be money and time ahead.
Old 05-13-2019, 11:07 AM   #7
webfoot
Re: Over cammed 402
What is the initial timing set at, with the vac advance unplugged?
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 05-13-2019, 11:39 AM   #8
68Gold/white
Re: Over cammed 402
Could be the tune.
Way too many unknowns here. Don't know what cam, if cam was degree'd, what heads, chamber volume of heads.
An off the shelf carb generally does not help...has to be calibrated to exact engine it is on...
General rule of thumb is to start with distributor. Has it been worked on???
If you have the funds, I know a guy in Tennessee that can dial in your distributor...if it is worth fixing...he IS good!!!
The 268H or 260H (NOT the XE cams!!!)are very good choices to change to, compression ratio needs to be known first......but not knowing what you have, I would do other things first...
68Gold/white is offline   Reply With Quote
Old 05-13-2019, 01:09 PM   #9
Whamp48
Junior Member
Re: Over cammed 402
Keeping the 402 because that's what come in it.
Old 05-13-2019, 01:12 PM   #10
Whamp48
Junior Member
Re: Over cammed 402
Yep, put in new distributor. Maybe after I get this thing to go to town and back, some fine tuning might be worth thinking about.
Old 05-13-2019, 01:58 PM   #11
geezer#99
geezer#99's Avatar
Re: Over cammed 402
Likely the best way to go.
Do a compression test.
The numbers should reveal some good (or bad) info.
Old 05-13-2019, 02:44 PM   #12
Minkota
Re: Over cammed 402
I have seen many engines set to a high idle to overcome the fact that they did not install a Converter with the correct Stall. Do you know what converter is installed in your setup?
Minkota is offline   Reply With Quote
Old 05-13-2019, 02:58 PM   #13
Ziegelsteinfaust
Re: Over cammed 402
Among the other things mentioned a torque converter designed for towing can be the culprit in poor idle or having to have it idle high to overcome fluid drag. Also the low stall or towing converter will make the truck slam in to gear when you shift from park to reverse for instance.
You need to do a full evaluation on your set up.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-13-2019, 04:22 PM   #14
Whamp48
Junior Member
Re: Over cammed 402
Yeah, I'll have to rip in to her. Take the cam out and take it to the machine shop. They're engine builders, too, so they can tell what it is. The heads are clean and have new looking rockers, so I'll have to look at them. I was told thwy had bigger valves. I just wanted to know from someone who knows what a good mild cam number was, and Greg gave me that. Thanks guys....I'll just have to get going on a job I was hoping wouldn't be necessary.
Old 05-13-2019, 04:55 PM   #15
Minkota
Re: Over cammed 402
Most aftermarket cams typically have the part number stamped into the end of the cam, you will be able to see it once you remove the top timing gear.
Old 05-13-2019, 04:58 PM   #16
Whamp48
Junior Member
Re: Over cammed 402
Thank you sir. I'm almost sure I'll find a cam that is not suitable for how I want the truck to run, but we'll see.
Old 05-13-2019, 06:01 PM   #17
webfoot
Re: Over cammed 402
So no clue on the timing then?
-me
Old 05-13-2019, 06:08 PM   #18
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Over cammed 402
I second the Comp Cams 268H, ran great in mine for years...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-13-2019, 06:38 PM   #19
Whamp48
Junior Member
Re: Over cammed 402
Other than turning the distributor to where it works best, no, I can't give you any technical answers on timing, degrees, etc. I'm going to tear into this thing next weekend and instal a mild cam and whatever valve springs go with it if mine are not suitable and I'm pretty sure I'll end up with what I want, a good running vehicle. Thank you for your interest.
Old 05-13-2019, 06:50 PM   #20
engineer_gregh
Re: Over cammed 402
I set my 402 exactly like this video even though the video is for a 350 not a big block. Its a good starting point. I hope it helps you.
https://www.youtube.com/watch?v=e-k2fdTZP7o
Greg Smyrna TN
Old 05-13-2019, 06:59 PM   #21
geezer#99
geezer#99's Avatar
Re: Over cammed 402
If you’re going to tear into, you mights we’ll pop a head off to see what pistons are in it.
If you have high compression (over 10 to 1) and install a mild cam you won’t achieve your goal. You’ll have a underpowered dawg that runs out of breath at 4000 rpm because you can’t put any timing in it.
Not much more to pop a head off.
You’ll need the drivers side off anyway to put #1 at tdc to be sure your timing tab/balancer are accurate.
Old 05-13-2019, 10:58 PM   #22
Whamp48
Junior Member
Re: Over cammed 402
Yeah, I'm thinking it'll have heavy springs, so I may have to replace them also. Easier to do with them off. How fast would you be going at 4000 rpm? 80?? I don't want to go that fast aboit 99% of the time. The 260H is a mild cam, but Comp says it has low end torque. We'll see.
Old 05-13-2019, 11:13 PM   #23
geezer#99
geezer#99's Avatar
Re: Over cammed 402
Take some pics of the pistons when you tear it down.
Old 05-13-2019, 11:16 PM   #24
Whamp48
Junior Member
Re: Over cammed 402
OK, will do. Y'all have a good rest of the night. Nap time for me.
Old 05-14-2019, 09:24 AM   #25
davepl
davepl's Avatar
Re: Over cammed 402
Take a look at the cam specs for the 396/350, and then look for a modern cam somewhat similar. That's what I'd do!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
