Old 05-11-2019, 02:32 PM   #1
MongooseV8
K10 and C10 Axle Shafts Interchangeable?
Hi Guys,
I have a 72 width C10 12 bolt axle housing and I want to convert it to the 6 lug pattern with a set of new axle shafts. I found a set of Moser shafts that I think will fit but they are for a K10 12 bolt. Do they interchange with a C10 12 bolt?
https://www.summitracing.com/parts/m...make/chevrolet
MongooseV8 is offline   Reply With Quote
Old 05-12-2019, 07:01 PM   #2
MongooseV8
Re: K10 and C10 Axle Shafts Interchangeable?
Anyone?
Old 05-13-2019, 05:12 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The 70 1/2 and earlier width is 62-3/8" from wheel mount to wheel mount.
The 70 1/2 and later (up to about 78 or so) width is 63-3/4" from wheel mount to wheel mount. Verify the axle lengths before you buy because the 72 housing will be the longer axles. Read this http://67-72chevytrucks.com/vboard/s...d.php?t=532198
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-13-2019, 09:29 AM   #4
MongooseV8
Hi thanks for the response. I have the wider 72 axle housing with the wider axle shafts. What I am trying to figure out is if the GM truck 12 bolt axle shafts are interchangeable between the C10 and K-10.
Old 05-13-2019, 09:58 PM   #5
fp1967
fp1967's Avatar
Yes they are.
fp1967 is offline   Reply With Quote
