Old 05-12-2019, 11:58 AM   #1
54blackhornet
54blackhornet's Avatar
M20 4 Speed Option ?
My 71 C20 has M20 listed on the SPID. Can you explain why ? Is it not the standard transmission ? Thanks fellas
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-12-2019, 12:15 PM   #2
Markuli
Markuli's Avatar
Re: M20 4 Speed Option ?
From what I understand, "m20" on your SPID means you have a "4 speed manual transmission". It doesn't mean you have a Muncie M20 transmission from the factory in your truck though, as that only came in cars. You either have a Muncie SM420, or its successor, the SM465. You most likely have an SM465 because the SM465 replaced the SM420 after 1968.
Markuli is offline   Reply With Quote
Old 05-12-2019, 01:04 PM   #3
54blackhornet
My bad ! The three speed on the tree was standard transmission right ? The M20 was optional so listed on SPID...thanks
71 C-20
07 Magnum RT AWD
Old 05-12-2019, 01:34 PM   #4
jocko
jocko's Avatar
Yep, anything other than 3OTT would have appeared on the SPID.
Old 05-12-2019, 08:39 PM   #5
71gmcC15
71gmcC15's Avatar
For the most part. My 71 gmc being the exemption. Has a factory 4 speed but not on the spid. Had a hole thread abut it bUT it never got solved
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 05-12-2019, 09:25 PM   #6
Astro-Balls
Astro-Balls's Avatar
Any modifications to the SM465 so it doesn't have a granny gear?
More like a M20 or M21?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-12-2019, 10:50 PM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
oops, nm
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-13-2019, 07:09 PM   #8
Markuli
Markuli's Avatar
Yeah, just swap it out with an M20
