11-28-2003, 01:37 PM | #1 |
hard starting after warmed up?
i have a 350 vortec crate motor it starts fine in the mornings or after it sits about an hour but if i drive it up to the store and try to run in and out it acts like the battery is about dead i just put a new starter on thinking this would fix the problem but it didnt timing seems to be right the starter i put on is one of those gear reduction high torq starter any help would be great
11-28-2003, 01:47 PM | #2 |
Inline 69
when you say replace starter,did you replace the soleniod also?did you replace the battery cables w/starter?????
11-28-2003, 01:49 PM | #3 |
Registered Cruiser
Welcome to the board! Try disconnecting the ignition, and then rolling the motor over with the starter. If it rolls over normally, it's not a starter problem, but an ignition problem instead. Make sure all of your cable, and battery connections are clean. Good luck.
I intend to live forever. So far, so good. |
11-28-2003, 02:14 PM | #4 |
yes i did replace the solenoid and cabels as well
11-28-2003, 02:20 PM | #5 |
How hot is it getting? My wife had a 65 Mustang that used to do this, turned out to be a cooling problem. The radiator cap wasn't holding enough pressure, and as soon as she turned it off it would over heat. Cold starting was fine.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
11-28-2003, 02:27 PM | #6 |
You running headers? They sometimes have the tendency to do that. You may just need some header-wrap or a heat shield.
11-28-2003, 03:07 PM | #7 |
Robert Olson Transport
sounds like ya need a heat shield there
11-28-2003, 03:13 PM | #8 |
My 68 burb did that when I first got it. I ended up discovering that I had the timing advanced a little too much. When it was cold, no problem, but hot, forget it.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
11-28-2003, 03:27 PM | #9 |
Mine was doing something similar. It had a new starter and soleniod and cables. I ended up getting an Optima red top battery (the battery that was in there was new, but it was a Costco battery) and the problem was solved and never came back again.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-28-2003, 03:54 PM | #10 |
thats what im doing right now waiting for my optima battery tobe deliverd
11-28-2003, 06:42 PM | #11 | |
Don't say "Oops!", Doctor
Re: hard starting after warmed up?
I've always timed my Chevy V8's by advancing them until they either A) start to detonate (ping) and/or B) are hard to start when hot. Sure, I could set 'em to what the book says, but every engine is different. I've had some that would let me get away with 14 degrees and others that wouldn't take more than 10. Either way, I'll be a gen-u-wine dollar bill that's the problem.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
11-28-2003, 10:19 PM | #12 |
When I worked at the Chevy dealer , many years ago. This was a
common problem. Gm had a heat shield we used to put on that goes around the solenoid. I don't know if they're still available or not?
"Negative people always seem to have a problem for every solution" |
11-29-2003, 06:14 PM | #13 |
my timing is set at 9 degrees before top dead center is that about right the specs say it should at 10 degrees anymore help out there
