Old 05-12-2019, 01:20 PM   #1
Furno68C20
Steering Column/wheel question
I want to go back to the 3 spoke steering wheel and horn button. The problem is I don't know if my column will work with the original wheel. attached are pictures of the wheel/button, and column with tilt.
I believe the column isn't original since it has tilt and the truck is a 68. Can a later column with a earlier wheel/horn button like I have?
Need to know what Steering wheel kit I will need. Can anyone help on this issue?
Thank you
Furno68C20 is offline   Reply With Quote
Old 05-12-2019, 02:43 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Steering Column/wheel question
It should work just fine as long as it's a Chevy tilt wheel column. You will need the horn stuff for the 67 model to fit inside the wheel.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
