05-12-2019, 11:05 PM | #1 |
bad fuel delivery 77 c20 dual tanks
Hello fellas I have another dreaded dual tanks/fuel tank selector valve question? Here's the story. I have a 77 C-20 that belonged to my father in law. From one day to the next the truck had no power/popping carburetor. After throwing lots of money and parts at it with no luck I realized I over looked the fuel pressure and low volume in the filter. I crawled under the truck and noticed the D/S fuel tank was by passed and the Passenger side tank was only hooked up. That explains why he would only fuel up on the passenger side. The fuel selector valve missing. I have read up on (hatzie) threads. I will need to replace the fuel sender and I noticed both tanks have the same 2 ports fuel sender. One port for fuel delivery and the other is just an open plastic nipple piece. Is this suppose to be a vent based on my pics? I don't believe this truck was designed to have return lines. I will replace all the rubber fuel lines while the bed is move back and get the truck running. Later down the road I hope to get the correct selector valve and get the fuel tanks operational. Any help is greatly appreciated. Thanx.
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
05-13-2019, 07:01 AM | #2 |
Re: bad fuel delivery 77 c20 dual tanks
The plastic vent looks funny, maybe it's broken. I'm 99% sure my 76's have return lines. If your plastic vent is open I would replace it and leave everything as is. You should check either fuel pressure or do a fuel volume test. I don't know the specs for fuel volume. I would probably be tempted to splurge $20 on a new fuel pump anyway.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-13-2019, 10:59 AM | #3 | |
thanx.
05-13-2019, 02:04 PM | #4 |
The plastic thing is the vent. My 75 has the same setup. You use the 1 wire solenoid 3 pipe valve to switch between tanks. Probably want to replace the dash switch if your gas gauge has problems, especially the go to 3 o'clock issue.
The vent should have a hat like thing over the end. Looks like yours may have broke and settled. Orange ring in 1st pic. Ask for a differential vent at the parts store. Should be the same thing. |
05-13-2019, 03:40 PM | #5 | |
05-13-2019, 05:48 PM | #6 |
I am running a Pollak valve. Don't remember the part #. Here is a link to a similar one on Summit: https://www.summitracing.com/parts/smp-fv1/overview/
Don't know if the Pollak valve is still made. Found a NOS one on Ebay a couple years back as a spare. Make sure both ends of the ground wires are clean as well. |
05-14-2019, 07:07 PM | #7 |
Moderator
Standard Motor Products makes the three port solenoid valve.
The early dual tank vent setup was just a differential type vent hooked to a Tee to both fuel tank vents. You can just run a short hose with a diff vent on each tank. Whatever you do you'll want the vent to be several inches higher than the top of the sender to keep fuel from sloshing out the vent. The early three hose evap cans are easy to plumb, don't cost you any performance, and they'll keep your garage from smelling like fuel on hot summer days.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-15-2019, 02:59 PM | #8 | |
Attachment 1903685
05-15-2019, 05:51 PM | #9 |
Hatzie now that you mention the fuel sloshing out the vent. Years ago I over filled the fuel tank and saw a small puddle of gas under the tank. I never did it again. Vent piece without the (hat/cap) I can see that happening.
05-15-2019, 07:00 PM | #10 |
Moderator
That should work on the stock single wire valve systems.
05-15-2019, 10:41 PM | #11 |
The OEM selector valve had short lifespans. 3 or 4 years if you were lucky. The Pollak valves usually last for decades. Uses the same wire and hoses.
05-16-2019, 10:28 AM | #12 | |
Thank you Chevy Brothers for all your help! Much appreciated.
05-17-2019, 10:54 AM | #13 | |
Only reason I traded it was to go from an automatic to a manual transmission.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
05-20-2019, 09:50 PM | #14 |
In 1980 A seperator valve ATE MY LUNCH!!! Over 100* for more than 30 straight days. I worked on it for all of those and more.
05-21-2019, 04:13 PM | #15 |
Got the Blue Goose running again! Thanks to all for the help
Now if I can figure how to turn the pics..
05-21-2019, 05:58 PM | #16 |
My factory replacement duel tank valve was leaking from the extra nipple for drainage in case of failure. The valve wasnt very old maybe a couple years. And the connector was full of fuel.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-24-2019, 11:02 PM | #17 |
I'll have to remember this. My new to me 78 has dual tanks and my driver sidejust kills the motor. Oddly enough it only has 16 gallon tanks so not being able to go far really really sucks lol
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
05-25-2019, 12:46 AM | #18 | |
Mine has 16 gallon tanks also. Check your selector valve and see if it has the 3 fittings with 1 power wire also. Check for power with ignition on. This valve I replaced is plumbed aux tank (left tank) and main tank (right tank). With ignition switch on Aux tank position/Left tank(valve energized). When you set switch to (right tank) Main tank the wire has no voltage/not energized. With some help from Hatzie I was able to figure out the installation instructions for the fuel selector valve.
05-25-2019, 11:13 AM | #19 |
Funny, my 1973 and my 1980 had 20-21 gallon factory tank(s).
The 1980 only had one factory tank (right side) but I had the dealer install a left side tank. It had a valve/switch but I can't remember if they put it in the middle of the dash just like the factory switch. I only had that pickup for about a year and a half.
